Dyna DS2-1 electric ignition installation
- Kingchiefa
- To each thier own.
30 Jan 2010 09:15
i cannot get the dyna rotor to fit over the cam. Has anyone else run into this problem and how do I fix it?
1979 KZ1000 ltd b3 Currently in Troy, PA. Hope to some of you on the road.
- TeK9iNe
- What did you do!?!
Re: Dyna DS2-1 electric ignition installation
30 Jan 2010 10:14 - 30 Jan 2010 10:29
Here's the origional Dyna instructions, incase you don't have them:
I had some difficulties with mine, so I just filed it slightly and used oil to slip it onto the cam.
It should spin freely, but not have too mush side2side play.
Good luck!
Good luck!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 30 Jan 2010 10:29 by TeK9iNe.
- Kingchiefa
30 Jan 2010 10:37
I have the instructions, I was thinking maybe if I just boiled the rotor in some water it might slip over the shaft, but the ID of the rotor is alot smaller than the OD of the shaft.
- TeK9iNe
30 Jan 2010 10:45
I just had some trouble there, trying to post the instructions. Good you have them though!
Are you sure you have the correct model Dyna S? What exactly is your bike again?
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Kingchiefa
30 Jan 2010 10:45
yeah nevermind the rotor is metal.
- Kingchiefa
30 Jan 2010 10:50
TeK9iNe wrote:
It is a 79 KZ1000 ltd b-3 I just bought the igniton from Z1enterprises.I just had some trouble there, trying to post the instructions. Good you have them though!
- TeK9iNe
30 Jan 2010 10:50
Ah, I see I have the same bike you do.
My Rotor fit right over the cam on that bike. I didn't have to make any modifications...
Are you sure that you have dissasembled everything?
By how much is the cam larger than rotor I.D.?
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Kingchiefa
30 Jan 2010 10:54
see that is where i am questioning my installation. I'm not sure I do have everything disassembled right. I cannot find a diagram or pictures that show what all should be disassembled.
- TeK9iNe
30 Jan 2010 11:02 - 30 Jan 2010 11:09
OK
Here is your advancer:
Remove your origional points plate and wiring completely.
Pull the small advancer swing arms (with springs) outward to release the stock rotor, and it should slide right off the cam. If it doesnt, the cam end may be dinged/damaged, in which case a small file can be used to clean it up. Then the rotor should come off.
Put the new Dyna rotor on in its place, pulling the swing ars open again to let the rotor seat. Then spin the rotor so that the magnet on it points towards the TEC marked side of the advancer, and the advancer arms click into the designated slots on the rotor.
When its finished, it looks nearly the same as the old one, and acts the same (still advances by tuning it slightly clockwise, and the arms move outward).
Hope this helps! ..and is correct :laugh:
Cheers.
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 30 Jan 2010 11:09 by TeK9iNe.
- Kingchiefa
30 Jan 2010 11:14
YES!!!! that helps alot man!!! I thought the original rotor was the shaft.. lmao. Thank you TEK9INE!!! I'll update when I finish not that you have got me past the hold up and tell you how it works out.
- TeK9iNe
30 Jan 2010 11:31
Excellent! I thought that might be the case, I've seen it before
Get her runnin' good!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Old Man Rock
30 Jan 2010 13:54
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
