Dyna DS2-1 electric ignition installation
  • Kingchiefa
  • Kingchiefa's Avatar Topic Author
  • To each thier own.
Re: Dyna DS2-1 electric ignition installation
31 Jan 2010 07:27
#345553
thanks fella's that helped alot. I got the ignition installed last night and installed new coils aswell. I waited until thismorning to fire her up due to not finishing until late. And I have a problem, plugs 1-4 are firing good, but 2-3 are not. I'm not to good with omhmeters and I'm trying to find the bad connection to the 2-3 coil. I also may need to redo the timing ( would this cause 2-3 not to spark?
1979 KZ1000 ltd b3 Currently in Troy, PA. Hope to some of you on the road.
  • Old Man Rock
  • Old Man Rock's Avatar
31 Jan 2010 09:10
#345580
Follow the static procedure using a +12Vdc light or DVM.
You sure you have +12Vdc, ground and EI module signal terminations to coil 2/3 correctly?
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • bill_wilcox100
  • bill_wilcox100's Avatar
31 Jan 2010 09:31 - 31 Jan 2010 09:39
#345586
That blue Insulation Displacement type connector used to tap into the +12 Vdc (+Batt) source is prone to failure. Don't ask. :blush: Other members have reported the same failure in the past.
You would be well advised to make a more reliable connection including just splicing, soldering and shrink tubing. This method is utterly reliable.
I wanted to be able to disconnect it if required so I went the connector route: See the 1 into 2 splitter on the Red line. Your colour code may be different since I have the Coil Repowering mod.:
Best of success, :)
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Last edit: 31 Jan 2010 09:39 by bill_wilcox100.
  • bill_wilcox100
31 Jan 2010 09:43 - 31 Jan 2010 09:46
#345592
...and this is how my Pickup plate was installed and labled:
Hope this helps, :)
Bill
Upgrades:
Montreal, Canada
Last edit: 31 Jan 2010 09:46 by bill_wilcox100.
  • Kingchiefa
31 Jan 2010 10:07
#345597
yeah bill that helps also. but I really need help with my timing, i hooked up my test light to my blck wire and it lit with the crank mark and the "T" mark alignied, assuming "T" meant timing i moved on to test 2-3 on the green wire, when the light lit up the crank mark was aligned with the two dashes to the right of the "F" mark on the 1-4 side... what the hell did I do wrong?
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
31 Jan 2010 10:51 - 24 Mar 2010 09:48
#345608
OK.
T = TopDeadCentre F = Fire (or idle timing), The 1-4 mark (farthest right) = Full advance.
Static timing should be done at full advance, IMHO.
Red power wire from dyna s to switched +batt power.
Black and green wires to corresponding coils.
The plate screws should be just snug, so that you can adjust the timing for 1-4.
The rotor should spin freely to full advance, then spring back completely to seat counter-clockwise.
Turn the crank until the advance mark on the 1-4 side is precisely lined up with the case mark.
Volt meter/light on black wire 1-4, spin the rotor to full advance and hold. Now rotate the dyna s plate either way until the light stays on. You can release the rotor, and tighten down the dyna s plate bolts.
Now move volt meter/light to green wire 2-3. Turn crank until advance mark lines up with case mark on 2-3 side.
Turn the rotor to full advance and hold.
Loosen screws and adjust the pickup itself (right side 2-3) until the light stays on.
Release rotor, tighten pickup back down.
Done.
Static timing is fine to get going, dynamic timing with a good light will yield best results...
Let us know...
B)
PS. Great pics everyone else!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 24 Mar 2010 09:48 by TeK9iNe.
  • Kingchiefa
31 Jan 2010 10:57
#345612
ok i'm gonna go try it.brb
  • TeK9iNe
  • TeK9iNe's Avatar
31 Jan 2010 11:15
#345613
All right, :laugh:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • Kingchiefa
31 Jan 2010 12:22
#345618
Man, I just don't know what I would do with out all my bro's here at KZRIDER!!!! Man the timing is perefect now thank you all for your help. You guys freaking rock!!!
  • Old Man Rock
31 Jan 2010 13:14
#345629
@ King... I guess the others forgot to mention....
We charge for these services for this crap ain't cheap you know.... $100 each! :blink: :woohoo: :P :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • TeK9iNe
  • TeK9iNe's Avatar
31 Jan 2010 15:27 - 31 Jan 2010 15:30
#345655
You're welcome man,
Now go out and enjoy that girl! :laugh:
... Mail my $100 to... click below... :P :lol: :laugh: :woohoo:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 31 Jan 2010 15:30 by TeK9iNe.
