three hot wires in the starter button?????
  • ready2ryde1985
  • ready2ryde1985's Avatar Topic Author
  • got to love these kzs
Re: three hot wires in the starter button?????
30 Dec 2009 15:19
#341241
also there is no switch on my clutch just a plug could this have somethin to do with it?
84 kz 700 a1
82 kz550 ltd
  • MFolks
  • MFolks's Avatar
30 Dec 2009 15:34
#341245
The clutch interlock switch wiring usually runs into the headlight housing, so check for jumpered wires or loose ones too.
  • Kawickrice
  • Kawickrice's Avatar
30 Dec 2009 15:38
#341246
Sometimes I have to push hard on the starter button to get anything to happen
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • ready2ryde1985
30 Dec 2009 15:47
#341251
sometimes i have to push hard on mine.
Why is that i took it apart and it seems to be working inside fine there is no change in the amps just 3 hot wires and a ground????
84 kz 700 a1
82 kz550 ltd
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
30 Dec 2009 16:45
#341253
It there a wire from the clutch lever? If so trace it down.
If you find a swithc for the clutch safety switch the little prong must be sticking out.
Some times they are removed and the prong taped up and the wires taped to the frame.
This is the first item i remove on a bike. I remove the switch and wire and put a jumper wire in the two connectors.
Follow all the wires on the starter switch.
Trace the wires on your wiring diaghram and touch each component.
You do have a trouble light to check for fire?
  • ready2ryde1985
30 Dec 2009 16:49
#341254
yep just got me a light goin to check that conect in the am
84 kz 700 a1
82 kz550 ltd
  • Kawickrice
30 Dec 2009 16:58
#341255
My spring inside of the button was messed up and sometimes it would not let contact be made. It was frustrating and took a test light to get it figured out what was going on.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • ready2ryde1985
30 Dec 2009 17:07
#341256
i used a voltom and got 3 hot wires and a ground nothin spikes when you hit the button ! if you switch it on and off the tach jumps
84 kz 700 a1
82 kz550 ltd
