three hot wires in the starter button?????
  • ready2ryde1985
  • ready2ryde1985's Avatar Topic Author
  • got to love these kzs
14 Dec 2009 19:33
#339020
I was replacing the clutch cable and putting back on my carbs and wanted to here it turn over . pushed the button and nothin . asked my step father to help me trubble shoot the problem and we came up with a bad silnoid . no big deal went to the shop and they no longer make mine so i purchesed one for a kz 1000 . put the wires together and noticed the wire ends "could only be one way and compared to the origanal that was the wrong way" so i switched them still nothin so i tore the starter button apart the key activates the lights and makes three wires in the switch hot but this is where im lost ! i would think there would be mabe 2 of the 4 hot then when you push the button mabe 3 hot idk???????? ive been scratchen my head for days it used to turn over fine!!!
batt has charge
conections are tight
in neutral
the clutch sensor is un plugged
any help welcome will post pics if needed
will have to be done in the day light
84 kz 700 a1
82 kz550 ltd
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: three hot wires in the starter button?????
14 Dec 2009 19:43 - 14 Dec 2009 19:46
#339025
Electrical is fun :laugh: :blink: Hope this helps!
Good luck.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 14 Dec 2009 19:46 by TeK9iNe.
14 Dec 2009 19:43
#339026
Is the Off-Run-Off switch in RUN position? :unsure:
Good Luck! :)
  • ready2ryde1985
14 Dec 2009 19:46
#339027
if in the run all three are hot and if off all three are hot
84 kz 700 a1
82 kz550 ltd
14 Dec 2009 19:59
#339035
Was thinking maybe the Off-Run-Off switch had been inadvertently clicked to the Off position.
My bikes won't crank over (i.e., electric starter motor doesn't engage) unless the Off-Run-Off switch is in the Run position.
Good Luck! :)
  • ready2ryde1985
14 Dec 2009 20:01
#339036
:( im lost my button wont go in if its in the off position but when in the on position nothin thanks tho
84 kz 700 a1
82 kz550 ltd
14 Dec 2009 20:26
#339049
Must be a different switch setup.
Here's the oem 1976 KZ900 right-hand switch gear.
Good Luck! :)
[Click on image to enhance view]
  • ready2ryde1985
14 Dec 2009 20:34
#339051
ya my kz 700 has the same off on off but that switch is the start button:silly: this is driven me crasy
84 kz 700 a1
82 kz550 ltd
  • TeK9iNe
  • TeK9iNe's Avatar
15 Dec 2009 16:02
#339152
Make sure all the proper connectors throughout the wiring harness are all plugged in, and in thier correct positions.
Many of the circuits are intermixed and require continuity throughout the entire system for everything to work OK.
Or just jump the solenoid with a wire and fire it up!
The starter just has to have its primary wire connected to the battery positive (via whatever) for the starter to spin.
Good luck!
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • keith1
  • keith1's Avatar
15 Dec 2009 16:14
#339155
batt has charge
in neutral
was the clutch sensor unplugged before?
  • ready2ryde1985
15 Dec 2009 16:58
#339166
was the clutch sensor unpluged before? no it was pluged in. ok so i tried to jump it useing a jumper "aka screwdriver" and the bat was weak so i filled it to the proper seting and trickled it . im tempted to take it to the dealer but my wallet cant take a beating like that !! I do not want to unwrap all the wires but i guess thats what im goin to have to do. i just dont know even where to start ?
84 kz 700 a1
82 kz550 ltd
  • ready2ryde1985
30 Dec 2009 15:17
#341240
pic of the switch in question
do these go bad?
84 kz 700 a1
82 kz550 ltd
