Source for KZ650 wiring harness?
13 Nov 2009 13:09 #333447 by seanof30306
Source for KZ650 wiring harness? was created by seanof30306
'79 KZ650 B3 (otherwise known as "that @#$%!!! KZ650)
Been trying to run down charging/wiring problems forever. The guy who is working on it says the wiring harness on the bike is in terrible shape, and would prefer to have another one.
I found one for a '78 KZ650B. Would that work? Are there better sources?
Thanks
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
  • Kawickrice
13 Nov 2009 13:16 #333450 by Kawickrice
Replied by Kawickrice on topic Source for KZ650 wiring harness?
It will probably be real close maybe a few wires or so different. Get the wiring diagram from both bikes and compare the differences......I grafted a KZ400 harness on to my Z1 and it was real close. I was gonna use it untill I could get a new one but that was three years ago.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
13 Nov 2009 14:08 #333454 by MFolks
Replied by MFolks on topic Source for KZ650 wiring harness?
Tried here? www.kz650.info/
13 Nov 2009 14:12 #333455 by seanof30306
Replied by seanof30306 on topic Source for KZ650 wiring harness?
I have a diagram for my bike. I guess I'll need the serial # of the bike I get the harness from to get the right diagram? What's a good source for a wiring diagram?
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
13 Nov 2009 14:28 #333461 by seanof30306
Oh, I see the wiring diagrams there. Thanks.
Any ideas on a good source for a harness?
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
13 Nov 2009 14:41 #333464 by anarki650
Replied by anarki650 on topic Source for KZ650 wiring harness?
I looked a LOT to find a reproduction harness for my 77b1 and was never able to source anything new. I ended up getting a really clean harness from a 79D2 (SR) and spent a few hours getting the sections that weren't a direct swap cut, soldered, and shrink wrapped to make a clean harness that was plug and play for my 77. The 77 has a one year only charging system, which is where most of my wiring work had to happen. Other than that you might end up with some extra wires in the hand control plugs or from your controls to that part of the loom (depending on if the bikes both have the hazard flashers or not). Pretty well any clean harness from any of the 650s will work with minimal effort.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
14 Nov 2009 05:44 #333583 by N0NB
Replied by N0NB on topic Source for KZ650 wiring harness?
I would think the '78 harness would be an exact fit. The only difference I can think of is that you may have a pair of wires going to the left hand pod for the lights on/off switch that was deleted later in '78/'79 to meet DOT regulations.
As Axton says, there is a big difference in the charging area between the '77 and '78 models. The later models are simpler wiring wise but perhaps not as robust (don't boost start from a running car or pickup, etc.).
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel :D )
14 Nov 2009 05:55 #333587 by seanof30306
Groan .... It was jumping that @#$%!!! KZ650 off from a pickup truck the day I bought it that started this two+ year-long nightmarish odyssy of electrical misery!
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
14 Nov 2009 06:24 - 14 Nov 2009 06:24 #333596 by N0NB
Was it running? If not, then you're probably okay. If it was running and the bike doesn't charge when you get it going, then you'll be in the market for the regulator/rectifier unit.
Nate
Last edit: 14 Nov 2009 06:24 by N0NB.
14 Nov 2009 06:52 - 14 Nov 2009 07:28 #333597 by seanof30306
It was running, and I've been through 4 regulator/rectifiers (the last brand new), and 3 stators (the last newly rewound) and more cussing and hair pulling than you can shake a stick at. I've never ridden it more than 400 miles without being left beside the road (thank God for AAA) with a dead battery (been through 3 of those, the last 2 brand new).
Clealy, there is a drain greater than the charging system's ability to charge. The last time it left me walking, I was riding at night. The headlight was aimed too low. When I adjusted it upwards, the lights immediately lost 1/3-1/2 their brightness, and it started running like crap. Soon afterwards, I was on the phone with Otis, the guy at AAA who has come to know me so well, telling them where to come get me and that @#$%!!! KZ650.
The guy who is working on my bike is a retired railroad electrical engineer who does amazing frame-off restorations on bikes. He knows his stuff. He checked it, and it's only putting 7 volts to the headlight. He is unable to locate the problem, and says the wiring harness is in bad shape, so he wants me to see about another one. I think there is a problem with the handlebar switches, as well. Sometimes the horn works; sometimes it doesn't. Sometimes the blinkers and emergency flashers work; sometimes they don't.
All I know is I want this to be over!
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
Last edit: 14 Nov 2009 07:28 by seanof30306.
14 Nov 2009 09:51 #333615 by anarki650
Pull the wires from inside the bars, pain in the @$$ but the only way to find any shorts that might be happening in there. And your guy is right, either tear into that harness and find the bad spots, or get a used one that's in great shape. I NEVER trust the internal condition of a wiring harness before putting it on though. Pull the wires out of the loom and make sure you don't have any broken, frayed, burned, roasted, melted, or slagged wires in there. Trust me, you DON'T want a wire fire to break out under your gas tank right in the middle of all that wiring...as me how I know that!!!!
09 Kawasaki ER6n
Omaha NE
14 Nov 2009 10:14 #333618 by seanof30306
OK, how do you know that?
79 KZ650 B3
Z1R 18" front wheel
Pumper carbs w/pods
WG coil mod
17/41 gearing
