1157 bulb vs 2357?
- polkat
1157 bulb vs 2357?
16 Oct 2009 20:04
I understand that the 2357 bulb will burn brighter when the brakes are on, as compaired to the old standby 1157 (and that the running light part of both bulbs burns about the same brightness). Sounds good for brighter brake lights.
But is there any disadvantage to using them? Too much amp draw? Too hot for the lenses? Anybody here switched to them?
- PLUMMEN
Re: 1157 bulb vs 2357?
16 Oct 2009 21:01
probably wont last as long as 1157
- bountyhunter
16 Oct 2009 22:53 - 16 Oct 2009 22:53
polkat wrote:
The 1157 is an 18W light on the brighter filament. That's already pretty hot. If you want brighter with LESS power, the Luxeon 3W LED bulbs fit the socket and are brighter than stock (also last longer). Get them at superbrightleds.com.I understand that the 2357 bulb will burn brighter when the brakes are on, as compaired to the old standby 1157 (and that the running light part of both bulbs burns about the same brightness). Sounds good for brighter brake lights.
Last edit: 16 Oct 2009 22:53 by bountyhunter.
- maestro
19 Oct 2009 15:25
i tried using an led lamp in my rear light/brake light but the kz sensing picks it up as a blown lamp-(not enough resistance) and keeps the brake light indicator on the idiot panel flashing
suzuki ts 125 sold
rd250 sold
suzuki 550 es sold
kz1000 a1
rd250 sold
suzuki 550 es sold
kz1000 a1
- polkat
19 Oct 2009 17:21
I went ahead with the 2357's and they work fine, but they don't seem all that much brighter with the brakes on. Of course, I'm observing this in daylight, so I'll take a look tonight after darek.
- bountyhunter
19 Oct 2009 23:25
maestro wrote:
True, you either have to install a smarter sensor like I did or add an external resistor across the LED to provide a low enough resistance to make the sensor happy.i tried using an led lamp in my rear light/brake light but the kz sensing picks it up as a blown lamp-(not enough resistance) and keeps the brake light indicator on the idiot panel flashing
- Old Man Rock
20 Oct 2009 05:28
Go LED indeed....
Think about just this little change and what it accomplishes...
18w/12 = 1.5amp draw.
3w/12 = .25amp draw.
That's HUGE and this was just for one little bulb!:ohmy:
Think of this in another way, you accomplish two turn signals where one turn signal is 23watts x 2 46watts to turn left or right...
23w/12 = 3.83amps versus LED's at .5 amps!!!!! :woohoo:
OEM Tail light is 8w for tail light and 23w for stop light.
8w/12 = .66amps
23w/12 = 1.92 amps.
Simple math here...For turn signals, tail/stop lights...
3.83amps + .66 + 1.92amps at any given time = 6.41 amps!
Whoa... :blink: When this all could be accomplished for under 2 amps!
That's a huge decrease in load demand of a 30 year old electrical system. Plus this additional current can now be delivered where it's truly needed, that's right boys & girls to your coils and ignition system!
Not to mention your battery charging system....
Here's the relay I used where no resistors were required thus saving all the current for where I really want it!
Hope this helps out....
This is a $12 LED load auto sensing relay I got at Auto-Zone...
8w/12 = .66amps
23w/12 = 1.92 amps.
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
The following user(s) said Thank You: Humenik
