ignition switch time...
  • Bluemeanie
  • Bluemeanie's Avatar Topic Author
11 Oct 2009 06:10
#326752
My '80 KZ650 F1 is in need of an ignition switch. It's so loose that if I hit a bump in the road the key pops out into my lap! I now have to start it up and then put key in my pocket. Problem is that there are about 10 differant switch assemblies on ebay. Mine has the plug (not sure how many wires) and a separate brown wire. Kawasaki.com says the switch (#27005-5007) fits my '80 F1 and '80 LTD only. None of the ebay switches show the separate brown wire and they talk about a 5 or 6 pin connector. Will one of these switches work on my bike and how to I finangle the "brown" wire? Anybody know which one of these switches are good and which ones are crap? Thanks guys... :)
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: ignition switch time...
11 Oct 2009 06:41
#326763
www.z1enterprises.com/detail.aspx?ID=369
Designed for your KZ 650 F1.
Cheap as dirt.
Brand new w/2 keys.
Ta hell w/flea bay.
Cheers!
B)
If you call Z1 Enterprises, they will be happy to answer any questions you have. They're super helpful. :lol:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • rstnick
  • rstnick's Avatar
11 Oct 2009 19:07
#326900
I guess that's a bad side effect of being able to ride year round, wearing out your ignition. ;)
What's your key look like? Got a pic.
If the key is worn, and it doesn't have enough "teeth" to it, it will pull out. A new key cut to factory specs may just stay in, unless of course the tumblers in the ignition are too worn as well.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
  • JMKZHI
  • JMKZHI's Avatar
12 Oct 2009 06:38 - 12 Oct 2009 06:45
#327009
Z1 probably sells an Emgo unit. I'd guess that one of those would be fine.
Maybe shoot them a quick question about the brown wire.
Here's a nos switch that shows the brown wire in the photo:
New Kawasaki Ignition Switch Assembly # 27005-5007 .
On the off chance that you decide to purchase it (it's pricy compared to the aftermarket item), be sure to verify that it's a genuine Kawasaki part.
I would search the part number on ebbayy to locate a new or nos Kaw switch, then ask about the brown wire & verify the mfg.
Last edit: 12 Oct 2009 06:45 by JMKZHI.
  • Bluemeanie
12 Oct 2009 06:53 - 12 Oct 2009 06:54
#327011
Re:ignition switch time... 11 Hours, 37 Minutes ago
It could be just the key but I doubt it after almost 30 years. I'd rather just put a new switch in... Thanks
That is my switch and proper part number but damn, don't have $85 floating around. Would love to get it as it is a NOS part! I guess I'll have to check wiring schematic about the brown wire and call the fine folks at Z1 and see what they say. The brown wire is unique to my bike only.
Any of you guys order switches on line and which ones to avoid?
Last edit: 12 Oct 2009 06:54 by Bluemeanie.
  • JMKZHI
  • JMKZHI's Avatar
12 Oct 2009 07:01 - 12 Oct 2009 07:02
#327012
Bluemeanie wrote:
... The brown wire is unique to my bike only....
My 81 650-CSR has the brown wire.
I'd guess that most if not all of the aftermarket units are Emgo.
PS: I sent you a pm.
Last edit: 12 Oct 2009 07:02 by JMKZHI.
