NEWBIE QUESTION ABOUT IGNITION
- waterwalker
- Thank you received: 2829
- Thank you received: 2098
Ive just recently bought my first kz. i got a 82 kz 750. the only issue i have with the bike is that it stumbles a little off the start but it clears up perfect after about 3000-3200 rpms. i was wondering what all i could replace on the ignition set up to make sure i had a good tune up. i already put new plugs(factory) and some good 100 octane gas also. again, it runs perfect after 32000rpms....
Hello, Jeff, and WELCOME to KZR!
We're glad you're here!
I concur with 650ed that carbs are a likely suspect. And thinking pilot circuits may need cleaning, and possibly different pilot jets. Or maybe just needs some low rpm tuning with the pilot adjuster screws.
Also wondering if original ignition with igniter is still being used, or if it has perhaps been replaced with a Dyna-S or other ignition.
But before further addressing the carbs, if not already done, would remove plugs and observe spark quality while spinning the engine over. Look for fat blue spark.
While the plugs are out, could also do a compression test, and assure that valve clearances are within specs.
Would also use a strobe type timing light to observe the advancer unit moving back and forth as rpm is varied by blipping the throttle. This being to assure the advancer isn't hanging in the forward position, and is immediately returning to full retarded position (F mark aligned) when the throttle is closed. A sticking advancer may impair lower rpm performance.
Imo it's good to first rule out any non-carb issues.
Good Luck!
- waterwalker
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- bountyhunter
- Thank you received: 337
I definitely vote for pilot problems, just went through this on my 750 twin. If the carbs are clean and no vacuum leaks or any other problems:Ive just recently bought my first kz. i got a 82 kz 750. the only issue i have with the bike is that it stumbles a little off the start but it clears up perfect after about 3000-3200 rpms.
My guess:
1) set gas (float) levels in bowls
2) rich up pilots (maybe need bigger jets)
3) rich up needle settings
I would also check the timing advancer and see if the advance follows the factory curve (see manual). If not,that will really screw up low end acceleration.
- waterwalker
- bountyhunter
I think yours is a four? I haven't done those, but you can go to babbittsonline.com (OEM section) and enter your model and year and get the explosion drawings for your carbs and it should show the parts.my problem is at the bottom end. the bike stumbles until about 3000rpms then it clears up. can the "pilot screw or screws" be adjusted on while the carbs are still on the bike? if so, where are they? i will be trying to locate a good manual in the meantime. thanks
Pilot adjust screw is 16014:
- muddy1
- 1980 Kz1000 LTD B4
muddy1
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
- waterwalker
- wes_scooter
or your ignition advance could be stuck in the advanced spot. i dont know if it is common or not. but seems possiable. i believe that around 3K is where it changes....
76' kz900
70' yamaha R5
2006 wr450f
Manuals frequently appear on ebay.
Could also try running some SeaFoam (or similar carb cleaning product) in with a tank of fuel.
Good Luck!
