Shut down on the road????
  • john8
  • john8's Avatar Topic Author
  • Anything unrelated to elephants is irrelephant
16 Sep 2009 19:28
#322082
I was going down thew road doing about 75mph and all of a sudden the bike shut down. I was lucky enough to pull on the side of the road. The lights work and headlight goes on but wont start. Why would it just shut off like that going down the road?:unsure:
I want to ride my bicycle!!!
  • john8
Re: Shut down on the road????
16 Sep 2009 19:52
#322085
Sorry, it is 1981 kz1000J.
  • timebomb33
  • timebomb33's Avatar
16 Sep 2009 19:54
#322087
blown fuse , also check to see if you may have hit the kill switch by mistake i have seen that before.
I THINK MY POWERBAND BROKE
  • MFolks
  • MFolks's Avatar
16 Sep 2009 20:06
#322088
Loose battery cables? Maybe tight enough for lights but not for high current draw.
  • john8
16 Sep 2009 20:25
#322093
Would it shut down while I am driving with a blown fuse?
  • john8
16 Sep 2009 20:28
#322094
There was a complete loss of power. Nothing until I pulled over...only the head light worked. Battery cables were tight.
  • ArthurGoVroom
  • ArthurGoVroom's Avatar
  • I'd rather ride it than shine it
16 Sep 2009 20:28
#322095
Might specify if the starter is working or not.
If it cranks but wont' fire, check the circuit that powers the ignition coils.
1976 KZ900A4, 4-1 header, rear lowering kit, grab bar removed, still shining and painting parts as time permits
  • john8
16 Sep 2009 20:29
#322097
It will not crank.
  • MFolks
  • MFolks's Avatar
16 Sep 2009 20:39
#322101
Time to get out the multimeter and see where power is and isn't. I'd open up the headlight housing and check the many and various electrical connectors.
On my 82 GPz1100 B2, a six pin connector controls the run/start switch that powers the ignition coils.Red wire
in and red with yellow stripe out.
Yours may have loose wires/corrosion requiring tank removal to check the push on electrical connections to the ignition coils.
  • arai59
  • arai59's Avatar
16 Sep 2009 20:39
#322103
Is your petcock in the "on" position ?
  • john8
16 Sep 2009 20:50
#322106
I did not run out of gas. :P
  • arai59
  • arai59's Avatar
16 Sep 2009 20:51 - 16 Sep 2009 20:52
#322107
As much as I hate to say...........my thought is with timebombs. Fuse or switch related.
Last edit: 16 Sep 2009 20:52 by arai59.
