Shut down on the road????
  • john8
  • john8's Avatar Topic Author
  • Anything unrelated to elephants is irrelephant
Re: Shut down on the road????
16 Sep 2009 20:52
#322109
Thanks MFolks I will try that.
I want to ride my bicycle!!!
  • john8
16 Sep 2009 20:54
#322110
Will a blown fuse cause complete power failure?
  • timebomb33
  • timebomb33's Avatar
16 Sep 2009 20:55 - 16 Sep 2009 20:56
#322111
oh my god what is wrong with the world, greg agreeing with me. and by the way a blown fuse will cause the power to shut down if it is the right fuse.
I THINK MY POWERBAND BROKE
Last edit: 16 Sep 2009 20:56 by timebomb33.
  • john8
16 Sep 2009 21:01
#322113
Thanks everyone...I will check all those things.
  • timebomb33
16 Sep 2009 21:05
#322115
do you have a test light or volt meter.
  • john8
16 Sep 2009 21:42
#322121
test light, yes, meter, no.
  • Skyman
  • Skyman's Avatar
16 Sep 2009 22:54
#322125
I've had the same thing happen to me twice. Once was due to a blown fuse. (which will indeed cut the engine immediately). I was only able to discover with a multimeter, because the fuse blew inside the metal cap, not visible through the glass.
I was halfway through a 500-mile ride, a long way from home. Fortunately, I packed a multimeter and extra fuses.
The second time was due to a wire that came loose from the coil relay mod I did.
West Linn, OR
  • bountyhunter
  • bountyhunter's Avatar
16 Sep 2009 23:25
#322127
john8 wrote:
There was a complete loss of power. Nothing until I pulled over...only the head light worked. Battery cables were tight.
My old ignition switch used to do that to me until I got smart enough to figure out what it was up to......:laugh:
  • YUKABODOS
  • YUKABODOS's Avatar
18 Sep 2009 09:42
#322372
Considering how easy it is to diagnose, I would pull the side cover, open up the fuse box and check the 20 amp fuse,, farthest to the right, with the white wire.
I have blow that fuse 2 times and the bike dies. No nothing. It is dead.
Pop in a new fuse and volia, back to life and all for 2 mins and a 1.20 fuse.
Yukabodos Buddy :blink:
