#4 cylinder not firing
15 Sep 2009 06:53 #321753 by grandadbob
#4 cylinder not firing was created by grandadbob
Hi to everyone....
I rebuilt my engine after it had been idle for 18 months and fired her up. I found a lack of power which turned out to be #1 and #4 cylinders not firing. I swapped the coils round but same thing. #1 then started working and I rode her hoping #4 would start. She never did.
Is there a way of checking if fuel is getting to the cylinder without taking the carbs off?....
Any other ideas on my problem would be welcomed.
Grandadbob.....in the UK
'83 kz550 C4
'06 VFR800 vtec
'83 KZ550 C4 LTD
'06 VFR800 Vtec
15 Sep 2009 07:50 #321766 by timebomb33
Replied by timebomb33 on topic #4 cylinder not firing
do you have a multimeter if you do i'd check the resistance of the no.4 plug cap if it checks out fine cut the end of the lead where the cap screws in back about 1/4" and reinstall the cap you should be getting around 5k ohm resistance on the plug cap. while your at it check no1 as well
I THINK MY POWERBAND BROKE
15 Sep 2009 08:44 #321769 by grandadbob
Replied by grandadbob on topic #4 cylinder not firing
do you mean take the complete lead of and measure resistance end tn end thro cap
'83 KZ550 C4 LTD
'06 VFR800 Vtec
15 Sep 2009 10:19 #321775 by MFolks
Replied by MFolks on topic #4 cylinder not firing
I think he means unscrew the sparkplug cap and measure from the spike that screws into the lead to where it secures to the sparkplug. On the caps that came with the bike from the factory, they push onto the sparkplug threads at the top of the insulator.
15 Sep 2009 11:02 #321779 by grandadbob
Yeah that figures but I don't think the problem lies there as I've swapped plug leads between #3 and #4, and #4 still not firing.. But i'll try anyway.
Thanks
'83 KZ550 C4 LTD
'06 VFR800 Vtec
15 Sep 2009 13:41 #321817 by MFolks
Might be a coil failure you're seeing. Do you have good compression,valve clearances been checked,and good fuel flow?
You could drop the carb float bowls looking for crud in the jets. This way it's possible to see if fuel is getting to the carbs.
15 Sep 2009 14:16 #321821 by 75z1
Replied by 75z1 on topic #4 cylinder not firing
I'm no real mechanic...but after you do a compression check, make sure that carb didnt com out of sync., then i would check valve clearence..and just for shit and giggles recheck your count on the timing chain to make sure u didnt have a little slack caught up somewhere and then after a turn over or two it came off count
15 Sep 2009 16:21 #321841 by Patton
Replied by Patton on topic #4 cylinder not firing
grandadbob wrote:
Hi to everyone....
'83 kz550 C4
'06 VFR800 vtec
If not already done, would first check for visible fat blue spark using brand new NGKB7ES plugs connected to caps and removed from outside cylinders with plug bases held grounded against the head.
As known, absent decent spark, a cylinder won't fire regardless of incoming fuel mixture.
Good Luck! :)
16 Sep 2009 05:30 #321939 by grandadbob
I have a spark but not a fat blue one. I get a good kick thro my hand from the other plugs and having swapped the coils round but still have the problem. I'm now checking resistances in the IC igniter.
I'll keep posting.
'83 KZ550 C4 LTD
'06 VFR800 Vtec
16 Sep 2009 07:52 #321958 by Patton
grandadbob wrote:
I have a spark but not a fat blue one....
:unsure: What is visible spark quality on the other plugs?
Am thinking maybe weak battery voltage to coils (a common issue).
With ignition switched ON, could use a voltmeter to measure voltage feeding into coil (often from red/yellow wires).
Btw, please don't be put off by responses including simple stuff already known, as it's there to possibly help an interested third party viewer.
Good Luck! :)
16 Sep 2009 07:57 #321960 by Patton
grandadbob wrote:
...Is there a way of checking if fuel is getting to the cylinder without taking the carbs off....
I usually just remove the spark plug and check for any fuel residue (wetness)or gasoline odor.
Would suggest assuring spark quality and compression before further addressing carbs.
Good Luck! :)
  • ArthurGoVroom
  • I'd rather ride it than shine it
16 Sep 2009 10:26 #321992 by ArthurGoVroom
Replied by ArthurGoVroom on topic #4 cylinder not firing
Have you switched spark plugs between cylinders? (i.e. take the plug out of #3 and connect it to the #4 plug wire and test the spark quality again). You might have a bad spark plug.
1976 KZ900A4, 4-1 header, rear lowering kit, grab bar removed, still shining and painting parts as time permits
