#4 cylinder not firing
- grandadbob
17 Sep 2009 04:55 #322135
by grandadbob
'83 KZ550 C4 LTD
'06 VFR800 Vtec
Replied by grandadbob on topic #4 cylinder not firing
I've tried all combinations of plugs etc without any change. Tried checking the IC igniter resistances but not very successful. Pulled carbs again and have found a blocked pilot jet drilling. Can't clear it with aerosol cleaner so I'll take it to garage for compressed air blast tomorrow.
I'll keep posting and keep smiling.
'83 KZ550 C4 LTD
'06 VFR800 Vtec
- wes_scooter
17 Sep 2009 05:01 #322138
by wes_scooter
76' kz900
70' yamaha R5
2006 wr450f
Replied by wes_scooter on topic #4 cylinder not firing
good to hear you found something. if you dont have inline filters you might want some. also treating the gas with aditive will help prevent that when it must sit. gas just isent what it should be...also sea-foam is suposed to help clean passages that might be working but are still gumed up.
76' kz900
70' yamaha R5
2006 wr450f
- grandadbob
17 Sep 2009 11:14 #322209
by grandadbob
'83 KZ550 C4 LTD
'06 VFR800 Vtec
Thanks for info on sea-foam.....I'm keeping my fingers crossed re the blockage.
'83 KZ550 C4 LTD
'06 VFR800 Vtec
- grandadbob
18 Sep 2009 03:06 #322331
by grandadbob
'83 KZ550 C4 LTD
'06 VFR800 Vtec
Bad news.....air line couldn't clear the blockage in the pilot circuit.....good news is there is definitely a blockage.
Anyone got any idea how to clear the circuit.
'83 KZ550 C4 LTD
'06 VFR800 Vtec
- ArthurGoVroom
- I'd rather ride it than shine it
18 Sep 2009 04:29 #322338
by ArthurGoVroom
1976 KZ900A4, 4-1 header, rear lowering kit, grab bar removed, still shining and painting parts as time permits
Replied by ArthurGoVroom on topic #4 cylinder not firing
You can use one of the wires from a fine wire brush to stab through it. Yes they say don't use wires to clean them...but IMO it's better to be slightly reamed out than totally clogged.
- timebomb33
- Thank you received: 10
18 Sep 2009 18:49 #322435
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic #4 cylinder not firing
if the blockage is really bad i'll use tip cleaners from a cutting torch they always work well for me or i'll also use small number drills they always work.
- grandadbob
18 Sep 2009 23:48 #322467
by grandadbob
'83 KZ550 C4 LTD
'06 VFR800 Vtec
Only problem is trying to clear round corners in the body. I'm taking the carbs to be ultrasonically cleaned today. See if that works!!!!!!
'83 KZ550 C4 LTD
'06 VFR800 Vtec
- wes_scooter
19 Sep 2009 06:05 #322478
by wes_scooter
76' kz900
70' yamaha R5
2006 wr450f
that should work, i've seen that take some very nasty carbs to a very good condition inside and out. i have a gallon of carb solution that i usuly let them soak in. works very good.
76' kz900
70' yamaha R5
2006 wr450f
- grandadbob
23 Sep 2009 14:55 #323538
by grandadbob
'83 KZ550 C4 LTD
'06 VFR800 Vtec
Got the carbs back....still #4 pilot jet circuit blocked. Back to the manual where I see the US model has a sealed air screw to comply with your emission laws. I removed the seal and the air screw and managed to clear the blockage. I'll try the carbs on the bike again.
'83 KZ550 C4 LTD
'06 VFR800 Vtec
- grandadbob
24 Sep 2009 12:04 #323678
by grandadbob
'83 KZ550 C4 LTD
'06 VFR800 Vtec
Good news...firing on all four...bit rough but i'm sure she'll respond to a bit of tlc.
Big thanks to all of you out there...surely we share the best site on the net.
'83 KZ550 C4 LTD
'06 VFR800 Vtec
- MFolks
- Thank you received: 540
24 Sep 2009 15:34 #323700
by MFolks
Replied by MFolks on topic #4 cylinder not firing
I find the welding tip cleaners sold at the welding supply stores to have the best small diameter wires for pushing out blockages. Here in the U.S. they sell for under $5.
Guitar strings and small diameter safety wire might work too.
