making my headlight brighter
  • XL777
  • XL777's Avatar Topic Author
11 Sep 2009 21:44
#320855
I was riding in the dark for the first time tonight and noticed the stock head light is really dim. Is there a way to increase the power going to the light if I were to get a higher output bulb?
2012 Triumph Bonneville SE black
1978 KZ1000 B2 LTD
Fresh top end rebuild
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
It is easier to say what I haven't replaced then what I have.
I must love this cruel mistress since she hates me
  • mzandmz
  • mzandmz's Avatar
Re: making my headlight brighter
11 Sep 2009 22:05
#320857
Make sure you stay in the legal limit for wattage.To bright in front means you'll have Two brights in rear(red and Blue)maybe even a noise like wooo wooo woooo.
New to Family, 1979 KZ440 LTD
  • mzandmz
  • mzandmz's Avatar
11 Sep 2009 22:09
#320858
How all your connections? Check voltage. Older Bikes like to eat up power through old connections causeing week volt/amprage making the head light dimmer then its suppose to be.
  • bountyhunter
  • bountyhunter's Avatar
12 Sep 2009 00:13 - 12 Sep 2009 00:15
#320870
I can't see your bike front in the picture. If you have the stock 7" round headlight, it is like a retarded firefly. You can get a standard 7" round halogen that drops right in and uses the same 35/55W as the stock bulb but is about 3X as bright. You can get them everywhere like wallyworld or kragens.
Last edit: 12 Sep 2009 00:15 by bountyhunter.
  • Old Man Rock
  • Old Man Rock's Avatar
12 Sep 2009 06:47
#320904
With the head light OFF, what is the measured voltage (Vdc) at the Battery (+) in reference to ground?
With the head light ON, what is the measured voltage (Vdc) at the Battery (+) in reference to ground?
With the head light ON, what is the measured voltage (Vdc) at the head light bulb in reference to ground?
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • MFolks
  • MFolks's Avatar
12 Sep 2009 11:47
#321063
Think about this too: If the headlight bulb wattage is increased, you will have an added increase in heat output.
Most bike's headlight housings are plastic and will melt/soften if say, you go to a 100 Watt high beam bulb.
Perhaps some aux driving lights controlled by a relay and wired into the headlight circuit are what you need.
Here's some ideas:
www.valueaccessories.net/Light%20Bar%20Wiring.htm
store.candlepower.com/ca53mohe.html
www.motorcyclehidlights.com/
www.jpcycles.com/Search/ProductDetail?sk...Ne=0&Ntk=All&Ntt=LED light&Ns=&results=10&No=
  • MFolks
  • MFolks's Avatar
12 Sep 2009 11:56
#321064
Another thought: If the headlight bulb is increased in Wattage, the switch gear may not be up to handle the increase in current without using a relay.
An alternator stator upgrade may be required to keep the charging system replenishing the battery at lower rpm's.
I think www.electrosport.com sells overwound stators that work at low engine speeds.
  • TexasKZ
  • TexasKZ's Avatar
12 Sep 2009 12:40
#321078
  • PLUMMEN
  • PLUMMEN's Avatar
12 Sep 2009 13:27
#321092
you guys are thinking way to hard here,try a new halogen bulb first then see how you like it .no sense in tearing bike to pieces untill you try the easy fix! :laugh:
  • TexasKZ
  • TexasKZ's Avatar
12 Sep 2009 13:37
#321093
Where's the fun in that?:P :P
  • Locozuna
  • Locozuna's Avatar
12 Sep 2009 14:50
#321103
Soooooo
Let me get this straight.
Your headlight is a dimmy
and you want to make it brighter.
:laugh:
:huh:
:blink:
:pinch:
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
  • bountyhunter
12 Sep 2009 23:07 - 12 Sep 2009 23:09
#321246
Yeah, I was beginning to think my previous post was invisible....:laugh:
Those 7" round halogens are not only brighter, they are dirt cheap because so many cars use them.
Last edit: 12 Sep 2009 23:09 by bountyhunter.
