making my headlight brighter
  • Old Man Rock
  • Old Man Rock's Avatar
Re: making my headlight brighter
13 Sep 2009 05:47
#321261
Not that I disagree with you guys regarding the halogens but does anyone know what his voltages are?
Reasoning, if not ~ +12Vdc @ the bulb, halogens ain't going to be worth a crap either....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • saxjonz
  • saxjonz's Avatar
  • KawboyZ
13 Sep 2009 06:46 - 13 Sep 2009 06:49
#321278
If you want bright buy a new headlight. The trillien tribar wave headlight is what you want and it comes with a halogen. If you are riding in pre 80 then that is what you should replace it with if you are riding an 80 up you could just buy a halogen bulb. I bought one for my bike and it was night and day brighter then I put the tribar on it and once again bigger difference yet.
It looks like you are riding a pre 78 in which case yes the bulb is crap and best to upgrade. You can get an 80 light or you can get the tribar. I am not sure but on ebay if car headlights 7 inchers will work then you can get a set for 50 if not then I got mine on amazon.com for 80 some dollars. Best investment in bright you can make if you don't have an 80 light.
79 LTD B3
Last edit: 13 Sep 2009 06:49 by saxjonz.
  • 1978KZ650SR
  • 1978KZ650SR's Avatar
  • If it's not one thing, it's something else.
20 Sep 2009 08:24
#322651
I have a halogen headlight, but I also added 2 small fog lights under it bolted onto the brake block.
Andrew
1978 KZ650 SR - Custom paint, Kerker cooler, 4 to 2 exhaust, inverted clubman bars.
  • TerryK
  • TerryK's Avatar
20 Sep 2009 11:24
#322702
I replaced the stock bulb and lens setup on my 77 KZ1000 with a sealed beam halogen many years ago with no problems whatsoever and at about 12 bucks a crack, it's a cheap but very effective solution to your problem.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
