Relay Fix on Ignition
- mzandmz
New to Family, 1979 KZ440 LTD
- Bluemeanie
- Thank you received: 14
- mzandmz
- bountyhunter
- Thank you received: 337
Tomorrow I will be putting on the relay to the coils to increase voltage from the old vintage 10.2volts and giving it a wopping 12volts.:woohoo: ,.My question to all those who have done this FIX, Is 10.2volts enough to properly power up the 12volt relay? I know how the relay works, but is that 10.2 going to give the relay enough switching power to keep the contacts together?:huh:
The wire that read 10.2V did so because of a big honking voltage drop caused by the coil current: stock coils are maybe 4 Ohms, so each one draws 3A. That causes a big voltage drop getting to the coils.
But, that line that previously carried 3A does not in the new circuit: the high current to the coils comes through the relay contacts from a direct feed from the battery. The wire that read 10V before should read over 12V now because it only carries enough current to close the relay which is probably about 0.2A. That will not cause any significant voltage drop.
- bountyhunter
Pop the wires off the + coil primaries and that wire will magically read 12.6V.Yes it gets 12volts through the relay. My question was according to the diagram you take the same wire that gets the lower voltage due to old wiring/contacts/switches is now used to switch on the relay.And that wire (yellow with red strip)is the one that only has 10.2volts. :dry:
No high current = no voltage drop.
- mzandmz
- Old Man Rock
- Thank you received: 225
Forget about the relay for a moment, Question, you measured the Red/yellow @ 10.2Vdc but no mention here (maybe I missed it) of the actual battery voltage measurement while running the engine...
Translation, @ idle for say, if the battery itself measure @ 10.2Vdc as well then this relay mumbo-jumbo ain't going to do a damn thing for you....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- mzandmz
- PLUMMEN
- Thank you received: 104
- mzandmz
- mzandmz
- bountyhunter
If the battery voltage is OK (above 12V) you should be getting more voltage at that line, unless some other high current load is hanging on it upstream like the headlight. I doubt that would happen for stock wiring, but it might have been modified.When I checked my voltage at the wire going to my coils(yellow/red stripe) I had the coils disconnected. I use a volt meter red to yellow/red wire and black to the battery ground. 10.2 volts, No coils were connected to draw honken currant. All I was showing was what voltage I was getting fron the battery when is has to go through the ignition switch then the kill switch and to the coils which weren't connected at the time I checked the yellow/red wire. so that beeing the case I still get 10.2 from the yellow/red wire going to relay. The other side of relay will send 12volts to new connection at coils
Did you measure the battery voltage directly first?
Remember, if you are truly getting a 2V drop along ANY circuit path, that drop has to be caused by a resistance AND a current flowing. It's possible the old switches have more resistance than original, but current has to be going somewhere to create a voltage drop.... and a 2V drop is a big drop.
