Will it hurt the bike...
- likes2gofast2009
1980 KZ1000 LTD "Brandi"
4-1 Kerker
Dyna Coils
More to come this winter!
- anarki650
- Thank you received: 5
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- bountyhunter
- Thank you received: 337
Depends what's wrong. If it's a healthy battery that just got run down, no problem. You can damage a bike running on a battery with a flaky cell because the battery filters the alternator's high voltage AC into smooth DC. If one cell is burnt and has a high impedance, you will get system voltage spikes. I took out about half my electrical system once kick starting on a flaked out battery and riding it. I got about a mile before it coasted to a stop dead. Popped all the small instrument bulbs, brake light bulb, headlight and my electronic ignition module. Expensive lesson.So my battery isn't strong enough to start the bike with the electric start, but it kick starts fine... Will it hurt the bike to run it with a half dead battery?
- saxjonz
- KawboyZ
- Thank you received: 76
Like bounty hunter says in a nice way. If you are cheap and try doing things the cheap way in the long run you will really pay much more. A tow or pushing your bike down the road while cars are flying by or just pushing it any length of distance will cure that flow of thought trying to come out of your head. I have been left high and dry a few times and it SUCKS and well... Peace of mind.
bountyhunter wrote:
79 LTD B3
- Old Man Rock
- Thank you received: 225
Fix it means get a new battery/check/measure/replace electrical components if required....
If the battery won't hold a charge of if one of the cells shorts out, you will be stranded at some point in time...
As far as damage, Bounty said it all for you.... Under +12Vdc to the coils, spikes to electrical components equates to run like crap with possibilities in damaging good components...
As Sax replied, fix the old girl!
She's informing you somethings not right with her so no more rides until you do...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- sarge383
kz 650d2 sr 79
- likes2gofast2009
4-1 Kerker
Dyna Coils
- saxjonz
- KawboyZ
What happens is that once a battery oxidizes it no longer will ever hold the charge it held before. Hence buy a new battery! Every time a battery decharges it oxidizes which does not allow the acid to react with the lead. The lead becomes white and it's cashishola. The best batteries have some kind of compound in them that retards the process but if you haven't kept up on her she is done for. Seriously.
But do what you think is best. Experience is the best teacher. I have had enough of that to last a lifetime as most of us have.
A good sealed cell yuasa battery costs 90 dollars a bit more expensive than your typical sears or walmart battery but not by much but....... THEY LAST MUCH LONGER. Word to the wise you get what you pay for.
79 LTD B3
