- Thank you received: 13
Need to install a kick-stand switch
- Sandy
- Fly High,Tony
Second day of our 2250 kilometer trip,we had a near crash because of the kick-stand.We had just pulled out of a view-point near Banff Alberta,and in the first left-hand twist it happened.Pushed us into the concrete barrier along the edge of the highway.
No serious damage to the bike,just footpegs,saddlebag got chewed,and the right-side engine guard bent up and busted the ignition-cover.Not a mark to us though.
If we DIDN'T have the saddlebags on,it would have been the Wardens knee-cap and leg.Her boot got a slight scuff on it...the boots that I JUST bought her,lol
She says she's SURE that I put the stand up(she saw me reaching for it) but I'm thinking that it didn't snap up into place.Either way...it's time to get a safety-switch installed,because like i said...it COULD have been ugly.Borrowed a new cover to get us home...all was good for the rest of the trip.We made SURE each time,to call out,"Kick-Stand!"
I have a Dyna2000 ignition system,and I'm wondering if I can use the factory clutch-switch WITH the Dyna2000,to somehow alert me if the kick-stand IS left down on take-off,once I wire up a contact switch down on the frame somewhere,where the kick-stand will activate it.
I'm open to any other ideas.
Thanks Guys.
1977 KZ1000 A-1
- Mcdroid
- Gone Kwackers
- Thank you received: 316
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Tyler
- Thank you received: 92
Use a micro switch on the kick stand somewhere. Tie into you nuetral safety in series with your kick stand switch and then use the relay to switch fused power to the horn. If you put the bike in gear with the kick stand down the horn would sound. It would take a bit of thinking but it would be pretty obvious you have a problem when the horn goes off, people tend to ignore indicator lights...
"74 Yamaha DT 400 Enduro
- JakeB
I would get a bit involved with a relay and a switch, so that if you had the kick stand down and the neutral switch was off (meaning the bike was in gear) the horn would sound.
Or you could wire it to the ignition so if you put the bike in gear with the kickstand down it would turn off the engine. My last bike was setup like that from the factory.
I wouldn't use the clutch switch because you would have to stand there holding it in while the bike warms up.
1978 Z1-R
- Sandy
- Fly High,Tony
And thanks,Craig.It was as close as I ever want to come.
It really upset the Warden,but like a champ,she shook it off and we continued on our way.We had a couple from Arizona,on their way to Alaska,stop by and he helped me pull the ignition cover off to inspect the internal parts for any damage before I fired it up again.They followed us until they had to turn off.2 MORE great biker-friends made on the road.
I'm thinking more of an ignition cut-out though,or something along the lines of not being able to turn the engine over if the kickstand is down.
What about tying in a kick-stand switch TO the clutch-switch,which already does NOT let the engine turn over unless the clutch-lever is pulled in...hmmmm.
The bike would never be able to run unless I was sitting on it with the kick-stand up,but no biggy,as I never leave it idling to warm it up anyway.
Doing that,you would have to have the clutch-lever pulled in AND the kick-stand up to start the engine.
Make any sense?
It would make for an easy(er) install,I think?
If I were to install a switch down on the frame,and then loop the wiring back into the clutch switch wiring??
1977 KZ1000 A-1
- Thank you received: 2829
- JakeB
Thanks for the replies,you guys.
Make any sense?
That would keep you from starting it with the kickstand down, but would not prevent you from putting it down once the engine is running.
1978 Z1-R
- Sandy
- Fly High,Tony
Just thought of something...
The clutch-lever has to be pulled in ONLY to START the bike,right?
Once it's running,you go to neutral and you CAN leave it to idle.
But like I mentioned,I never leave the bike running unattended anyway.
I sit on the bike while I'm putting it through the choke stages,and once it's running good with the choke off,I shut it down and then get geared up,so...
I've heard too many stories where the rider fires up the bike from cold and then walks away,only to hear the engine start to rev up,searching for red-line.:ohmy:
1977 KZ1000 A-1
- Sandy
- Fly High,Tony
Another option (at least until you find a better solution)is to make a habit of using the centerstand. I very rarely use my sidestand; after a short while using the centerstand becomes automatic. I've never seen or heard of anyone driving off with the centerstand down. Ed
No center-stand,Ed...but thanks Bud
1977 KZ1000 A-1
- JakeB
Yeah, the clutch switch only locks out the starter not the ignition. Which is why if you wired your kickstand switch through it you could put the kickstand down again once the bike is started.
1978 Z1-R
- Sandy
- Fly High,Tony
[/quote]
Yeah, the clutch switch only locks out the starter not the ignition. Which is why if you wired your kickstand switch through it you could put the kickstand down again once the bike is started.[/quote]
And that's all I need,because I'm never on the bike with it running and the kickstand down at the same time.
I only have the bike running once I'm(we're) ready to pull and go.
As long as the switch would prevent me from starting the engine with the stand down,that's good enough.
I'll put more thought into it though,once I get there and get into doing it.
Now I have to find a good quality switch that will hold up to the elements,etc.
1977 KZ1000 A-1
- Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
