- Thank you received: 4
HELP!
- Vter Bob
25 Jul 2009 09:18 - 25 Jul 2009 09:19 #309249
by Vter Bob
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
HELP! was created by Vter Bob
1982 KZ1000 LTD. 29,000 miles. No electrical modifications except for the addition of a pair of Stebel Magnum horns. These were wired with a relay. The charging system is not working. Freshly charged battery (Load tested) reads 12.8 volts. At idle I read 11.6 volts and at 4,000 rpm I read 11.5 volts. Bike starts and runs great on freshly charged battery. All electrical devices work as they should. I have an FSM and I have a Clymers. I went through both manuals and checked everything as instructed and convinced myself that the reg/rec was shot. I have just replaced the reg/rec and in the process went through every connector (again), cleaned with contact cleaner and applied dielectric grease. I inspected the harness visually and saw no signs of chafing or breakage. I cleaned both ends of both the Pos & Neg battery cables and assured there was a good solid connection. I still get the same voltage readings! What have I missed? Oh, I have 50 volts on all three yellow stator wires at 4,000 rpm and with the connector unplugged and my volt/ohm meter set to the 20 scale I read .5 across any combination of the yellow wires. The only thing that doesn't seem normal is reading from each yellow wire to chassis ground I get readings from .6 to 1.7 while on the same 20 ohm scale.
HELP!
HELP!
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
Last edit: 25 Jul 2009 09:19 by Vter Bob.
- Motor Head
- Thank you received: 391
25 Jul 2009 16:58 #309288
by Motor Head
Replied by Motor Head on topic HELP!
Are you getting power at the regulator? There are two wires that have power. 1 is the coming from the regulator through to the battery for charging, white and red striped.
The other is B+ at key on, Brown in my book, this also feeds many circuits like the gauges etc.
Then of course there is the ground, yellow/ blue striped. Of course I am sure when you checked the stator voltage it was at the 6 pin connector where the regulator plugs in?
Hope this is some help.
- gane
- Thank you received: 1
25 Jul 2009 17:33 #309293
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic HELP!
VTER, Consult your manual, but my experiance is all three of your stator output leads need to be at least 3 meg above ground. I'm thinking pinched wires or cooked stator. luck g
- kpier998
25 Jul 2009 18:57 #309302
by kpier998
Replied by kpier998 on topic HELP!
I had the same model bike (still do, but being rebuilt) in the mid to late 80's and I had a problem where the wires come from the stator to the outside of the cases. I believe this is all under the front sprocket cover. Anyway, there are connectors there where the wires can be disconnected or have been crimped together or something. One of mine was not making a good connection at that joint and would occasionally cause it to quit charging. It might be worthwhile to check that area carefully. I spent some money replacing things that didn't need to be replaced before I found the problem.
- asevans
25 Jul 2009 19:58 #309311
by asevans
1976 kz900 Mostly stock
1978 Z1-R Project
Replied by asevans on topic HELP!
I had the same deal on my kz900. one of the wire in the stator cover was completely broken. didnt have much wire to work with either.i got wire couplings and shrink wrap and got it fixed though
1978 Z1-R Project
- bill_wilcox100
- Thank you received: 5
25 Jul 2009 20:32 - 25 Jul 2009 20:35 #309325
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic HELP!
VB, the voltage out of your Alternator seems high compared to what I read on my KZ650-B1.
My Rectifier output is about 1/2 the Alternator or:
... 28-30 Vac/2 = 14-15 Vdc.
Your Rectifier output of about 50 Vac should product about:
... 50 Vac/2 = 25 Vdc. Could this be a meter reading error?
See below the readings from my B1. Note that I have installed a Terminal Strip to provide Test Points. They are not protected by inline resistors so I have to be very careful not to short any of them.
Maybe yours works a bit differently... I don't know.
Best of success.
Bill
Best of success.
Bill
Upgrades:
Montreal, Canada
Last edit: 25 Jul 2009 20:35 by bill_wilcox100.
- Vter Bob
26 Jul 2009 17:37 #309458
by Vter Bob
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
Replied by Vter Bob on topic HELP!
I think I have figured out my problem. This bike is possessed by a @*^$^&^# Evil Spirit.
A friend stopped by today and we tore into the bike. We opened up the harness and every wire was checked. I checked for continuity, did the "wiggle" test on everything. Everything checked out fine. Put back together it still exhibited the same problem, no increase in voltage across the battery terminals at 4,000 rpm. So we again went back to page one of the manual and started all over again. Now, with the connector unplugged, meter set to 200VAC I'm reading 3 to 4 volts on the yellow wires from the stator. Doing a resistance test I have .5 ohms across 2 wires but read OL when measuring between the third leg and either of the other two yellows. I also noticed that the left engine cover where the stator is mounted became to hot to touch after only 2 minutes of engine idling or revving to 4,000 to check voltages. 20 minutes after the engine was stopped, the cover was still to hot to leave a finger on more than a couple of seconds.
Anyone versed in exorcism? I'm not the sharpest knife in the drawer, but I am sure the stator checked out fine before, now it seems shot.
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
- MikeinN.H.KZ1Kst
26 Jul 2009 17:54 #309464
by MikeinN.H.KZ1Kst
Replied by MikeinN.H.KZ1Kst on topic HELP!
Wish I could help but I'm currently experiencing electrical problems w/my 79 GL1000 blowing 5amp fuses & killing the engine. I HATE electrical problems. As to the being possessed part, have you ever been to a Blessing of the Bikes gathering? Hey, couldn't hurt, right?
- Vter Bob
26 Jul 2009 17:57 #309466
by Vter Bob
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
Actually I have been to one on my 550. It runs fine.... :blink:
I will gladly take the 1000 if I can get it to run! :laugh:
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
- Kawickrice
- Thank you received: 18
26 Jul 2009 18:05 #309469
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic HELP!
Electrical Gremlins SUCK. They will make you bald from pulling your hair out. :laugh:
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- bill_wilcox100
26 Jul 2009 19:32 - 07 Sep 2009 14:12 #309499
by bill_wilcox100
Upgrades:
Montreal, Canada
Call me silly, but it sounds as if you have identified the possible faulty assembly. :silly:
So how much do you figure it's going to cost to replace the stator?
Best of success.
Bill
Best of success.
Bill
Upgrades:
Montreal, Canada
Last edit: 07 Sep 2009 14:12 by bill_wilcox100.
- MFolks
- Thank you received: 540
26 Jul 2009 20:50 #309508
by MFolks
Replied by MFolks on topic HELP!
Have you used the trouble shooting guide at
www.electrosport.com
