trying to get a project running - need some help
- sharkynrk
Re: trying to get a project running - need some help
18 Jul 2009 07:15
ok so i got another ic ignitor and put it in and nothing changed. so now I am looking to find another something that is wrong. i know that i am not getting any spark, and it looks like the ic ignitor is not properly grounding and ungrounding as the rotor passes through the pick up coil. looking at the ic ignitor I see 9 wires. 12v power, ground, 4 pickup coil wires, 2 ignition coil wires, and a wire to the junction box. the wire to the junction box goes to a diode plug that has three wires itself - kill switch, side stand, neutral.
now my meter read that the neutral switch is correct and i am getting a neutral dummy light, my meter said that the side stand is up and i am not getting the dummy light that says its down. how can i verfiy the kill switch is not stopping the ic ignitor from running? i had checked continuity previously on that switch and it looked good
what else can be stopping me - this is the roadblock
- sharkynrk
20 Jul 2009 11:08
any chance the start relay would allow the starter to turn but not the ic ignitor fire - or perhaps the diode bank?
- sharkynrk
21 Jul 2009 11:16
anyone have any other ideas? pretty stumped
21 Jul 2009 11:52
If reading correctly, am understanding there is a green signal wire from igniter to a primary terminal on one coil, and a black signal wire from igniter to a primary terminal on the other coil.
Perhaps the green and black wires are reversed and not going to the correct coil. If not already done, could experiment by reversing the connections of the green and black wires to the coils.
This may not help anything, because seemingly the plugs would fire anyway with the wrong signal wire connected, just not firing at the correct time.
Just a thought.
Good Luck!
Just a thought.
Good Luck!
- sharkynrk
21 Jul 2009 17:46
yep, i pulled a plug and tried it on all four wires and none of them fired - thanks alot for the response though. at this point I really have a feeling that its got to be something that would uniformly stop the ic ignitor from firing anything, but can't seem to find what it could be
21 Jul 2009 18:17
When the secondary winding loop was ohm-checked on each coil, were the plug caps installed during the ohm reading?
Could re-check secondary loop resistance with plug caps attached to help assure the caps are conducting, as sometimes the resistor chip built inside some caps can go bad, or maybe one or more caps is not properly connected to the plug wire.
Just thoughts. Still pondering.
Good Luck!
Good Luck!
- sharkynrk
21 Jul 2009 19:11
i pulled off the caps and wire so that i was checking the resistance over just the coil - without the wire. i was wondering if some how the wire coil connection could be the issue but for all four of them to be messed up?? i will happily check them again - what exactly should i be looking for
22 Jul 2009 02:40
Because it's a loop, any disconnect between plug caps will disallow spark on both plugs.
Would ohm check between plug caps, to assure continuity throughout secondary loop.
Good Luck!
Good Luck!
- sharkynrk
22 Jul 2009 06:45
i will try that, just pull the plug wires and check for continuity between 1 and 4 and 2 and 3. I will post up when I get a chance to check - gotta go have oral surgery today so I will be out for a few. thanks again - and if anyone has any other ideas feel free to post up - I will take all the help I can get
- sharkynrk
23 Jul 2009 03:07
i was off by a day on my oral surgery, its today so I had a minute to check the above. i have a resistance of 21kOhms between the plug caps of 1 and 4 and 2 and 3.
- sharkynrk
23 Jul 2009 20:50
That's only eight wires, guessed as follows:
ONE 12v red/yellow power wire
FOUR pickup coil wires (2 to each pickup)
TWO ign coil wires
(black signal wire to one ign coil)
(green signal wire to the other ign coil)
ONE black/yellow ground wire
What is the 9th wire?
Bat+ on red/yellow to ign coils from igniter should exist only with the ignition switch turned ON (and am presupposing this is the situation at hand).
With bat+ to coil, and grounded via signal wire through igniter, thereby creating magnetic field, the UNgrounding (via pickup coil to igniter) collapses the magnetic field, sending high intensity voltage through the secondary loop (firing the spark plugs). Am thinking the grounding function during coil charging time relies on the black/yellow wire from the igniter.
Is it certain that the black/yellow ground wire from the igniter is properly grounded? Could ohm-test black/yellow wire from igniter to engine.
Do the pickup coils rely on a power source? (As does the Dyna-S). And if so, has switched bat+ to pickup coils been verified?
Just shotgunning.
Good Luck!
...not getting any spark, and it looks like the ic ignitor is not properly grounding and ungrounding as the rotor passes through the pick up coil. looking at the ic ignitor I see 9 wires. 12v power, ground, 4 pickup coil wires, 2 ignition coil wires, and a wire to the junction box. the wire to the junction box goes to a diode plug that has three wires itself - kill switch, side stand, neutral...how can i verfiy the kill switch is not stopping the ic ignitor from running? i had checked continuity previously on that switch and it looked good...what else can be stopping me - this is the roadblock
TWO ign coil wires
Just shotgunning.
Good Luck!
