trying to get a project running - need some help
- sharkynrk
- KaZooCruiser
- Thank you received: 7
Espeially the sidestand interlock thing.
- KaZooCruiser
went back and saw that. . .so I guess you been there, done that. . .
I'll go away now.
- sharkynrk
on my 6R if you are in neutral and the kickstand is down you can start, but if the kick stand is down and your in gear you cannot.
- sharkynrk
- txturbo
- Ex-Kawasaki Mechanic 1981-1985
1984 ZX750 E1 GPz Turbo
1984 ZX1100 A2 GPz
1984 ZX900
1996 KZ1000P Police bike
1970 Honda CT 70H 4sp manual
1965 Honda Dream 305
2003 Honda Shadow 1100
1971 Suzuki MT50 Trailhopper
1969 Camaro SS
1966 Impala
1966 Impala SS 427/4spd
- txturbo
1984 ZX1100 A2 GPz
1984 ZX900
1969 Camaro SS
1966 Impala
- sharkynrk
Have you checked for continuity on the wires between the components? A broken wire somewhere will do this also. I would check for continuity on the ground wires between the coils and igniter connector and then make sure pulses are coming out of the pickup while cranking.
ok I want to try some of these items but let me give you some more info. I had to redo the wiring harness so I checked continuity between every spade / pin on the harness and to its corresponding plug before putting it on the bike.
I cannot say for sure that I have checked for continuity between the plug that plugs into the ignitor and the connector spade that goes to the coil. Its a green and black wire that runs from the ic ignitor plug to the spades - and I can check that tonight to makes sure.
I have put a meter between the wires on the pickup coil and turned the motor over to check resistance but the meter response is either not fast enough or I am not getting anything. Can this be tested by hand cranking the motor with a ratchet? Is that what I should be testing - putting a meter between the two "magnet" wires on the pickup coil and measuring resistance - they ohm at 450 or so off the bike - what should they read as the rotor passes by the pickup?
- sharkynrk
You could also try manually touching a ground to the ground side of each coil and watching for a spark on one of the corresponding spark plugs.If you get a spark at the plug doing that, then you have a break in the ground side of the harness and your igniter is good.
I will try this again - I have tried it once and got nothing but the kickstand was "down" - ie switch was backwards - and I have not tried it since. I don't quite see how this will work though. I mean if I manually ground the coil, how is it testing the ignitor. Doesn't the ic ignitor after seeing the pickup coil - ground the ignition coil, causing it to discharge a spark.
if you just ground the coil wouldn't that take the ic ignitor out of the picture?
- Thank you received: 2098
txturbo wrote:
...Doesn't the ic ignitor after seeing the pickup coil - ground the ignition coil, causing it to discharge a spark....
It is the ungrounding of the ignition coil that causes the spark.
While grounded, the bat+ voltage into one primary terminal is going through the primary winding and out the other primary terminal to ground (creating a magnetic field inside the ignition coil).
When the ignition coil primary winding ground is interrupted, the magnetic field collaspes, which causes high voltage throughout the secondary windings loop which includes the spark plug wires.
Good Luck!
- loudhvx
- Thank you received: 1616
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- sharkynrk
anyways, I will try and get at it again after I get it fixed.
