Getting The Factory Smoke Back in The Regulator
  • Kawickrice
  • Kawickrice's Avatar Topic Author
30 Jun 2009 17:00
#303457
So I went to go for a ride this afternoon after a pouring rain. When the bike started I noticed what I thought was steam from the rain burning off the exhaust, wrong, it was my voltage regulator/rectifier. My question is how do I get the factory smoke back in the regulator. :P
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • bountyhunter
  • bountyhunter's Avatar
Re: Getting The Factory Smoke Back in The Regulator
30 Jun 2009 17:40 - 30 Jun 2009 17:41
#303461
Kawasaki sells OEM smoke in eight ounce cans, but the aftermarket smoke costs less and works OK.
What's really tough is to get the OEM insulation to go back on the melted wires.....
Last edit: 30 Jun 2009 17:41 by bountyhunter.
  • gane
  • gane's Avatar
30 Jun 2009 18:01
#303468
DO NOT attempt replacing w/english smoke. It is for postive ground systems ONLY.G
[img][/img] 1977 KZ1000A1
  • Vter Bob
  • Vter Bob's Avatar
30 Jun 2009 18:35
#303476
You got a part number for that smoke? I can't find it. I read on another forum that you could drill a small hole in your reg/rec, connect the exhaust end of a shop vac then burn some blinker fluid, suck up the smoke with the vacuum hose then quickly plug the hole you drilled. One guy over there said he did it and it's been working real good for a couple years. His name is "Needa Jump".
Ahyut, no more St. Pauli Girls for Bob tonight....
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
  • Kawickrice
30 Jun 2009 19:06
#303490
I think I will try the shopvac trick. I will stay away from the English smoke also.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • Old Man Rock
  • Old Man Rock's Avatar
30 Jun 2009 19:46
#303505
Well Plummen is up in Craig's area...
Craig, have Plummen work on your KZ, capture the smoke for Kawickrice and mail him the remnants.... :laugh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Mark Wing
  • Mark Wing's Avatar
30 Jun 2009 20:26
#303517
Wow I always thought when I let the smoke out that was it. S#!t I never knew you could get replacement smoke. Dam.
Mark
Yorba Linda Cal.
  • KawiConvert
  • KawiConvert's Avatar
30 Jun 2009 21:20
#303529
Mark
Technically the OEM smoke is out of production so you need to slip the guy at the parts counter a 50 just to see if they might have the smoke specific to your bike in stock. California is worse, they recently outlawed anyone but factory authorized techs from installing or replacing smoke. So unless you already have some smoke on hand you couldn't legally buy it if it was in stock.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
  • PLUMMEN
  • PLUMMEN's Avatar
30 Jun 2009 21:35
#303532
ive got a friend who can get ya the right smoke,but you need to make sure youve got the right fittings for the bucket for him to ship it to ya! :laugh:
  • bountyhunter
30 Jun 2009 21:57
#303541
Ah, yes... the english had a 50-50 chance and got it wrong. My misspent youth in my MGA and building up antique jaguars.
If you are ever cursing over an electrical problem, just be grateful it's not British. The man named "Lucas" was officially dubbed "the prince of darkness" for his prowess at building completely unreliable electrical systems......:laugh:
  • trianglelaguna
  • trianglelaguna's Avatar
30 Jun 2009 21:58
#303542
if the smoke only started when you got in the garage then you should be able to look inside the roof line and see where it gathered...it may need to get shipped out to a guru for a rebuild and that can sometimes take a while.....best just to learn how to rebuild smoke yourself...but wtf...it's your money do as you wish...good luck craig
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • bountyhunter
30 Jun 2009 22:00
#303543
KawiConvert wrote:
Mark
In kali the EPA requires that the smoke is pre-filtered to remove all the offending pollutants which leaves only Arnold Schwarzenegger fart remnants. Not as good as actual smoke.
