Rear signals
- clutch
- I wish I had a tad more patience to do it better!
Rear signals
22 May 2009 22:31
Hey guys,
I recently noticed that the rear signals on my 82 kz750e are not working. After a quick look, the ground appears ok, because the tail/brake light runs off the same wire. I just ordered a new set of signals, so I haven't done a thorough check yet. I was hoping someone might have some insight as to the issue.
Questions:
1. Front and rear are on the same or separate fuse?
2. Could the issue be at the control switch, or is it an inline circuit?
3. Are maybe the bulbs both blown on the rear?
4. Anything else you can think of?
Thanks,
Clutch
Questions:
Thanks,
Clutch
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I say more?)
Wish List:
- bountyhunter
Re: Rear signals
22 May 2009 22:56
Normally, the front turn signal filaments are hard wired to the rears (left front/rear tied together, right front/rear tied together). If the front gets power, the rear should too unless the wiring is damaged. So, they normally share a single fuse. Check bulbs first.
- clutch
Re: Rear signals
23 May 2009 11:26
Everything is working fine now with the new signal lights in the rear...must have just been the bulbs!!
Wish List:
Wish List:
