180 degrees out?
- Jack
180 degrees out?
19 May 2009 08:33
Got the wiring hooked up and put gas in the old girl last night after a winter long tear apart/rebuild that turned into a winter/spring affair...but it won't fire.
Everything electric works,starter,horn lights, got spark and gas. But the bike won't fire and backfires after trying.Didn't have time to get into it last night and it's been a long long time since I worked on anything electrical on this bike- 79 MKll.
OK, is it possible to hook up the wires from the coils 180 degrees out or should I be looking for something else ? Changed the coils to 3 ohm.Dyna units with new wires and maybe didn't reattach them in the correct sequence. Didn't have the Dyna ignition plate out of the engine so timing can't have changed.
Not much good on electrical headaches and hope someone here might point me in the right direction.Thanks!
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
Re: 180 degrees out?
19 May 2009 09:25
Left-side Dyna-S module signals whichever coil is firing outside cylinders.
Right-side Dyna-S module signals whichever coil is firing inside cylinders.
Good Luck!
Good Luck!
- OnkelB
19 May 2009 09:30 - 20 May 2009 14:34
You might have accidentally swapped the coil trigger wires.
Remove the timing cover and look at your timing plate. There will be two wires coming out, one from each pickup coil (a black and a white if it's a DynaS). The wire from the left pickup triggers your 1/4 coil, the wire from the right pickup triggers the 2/3 coil - check that the coils are connected accordingly. That is the wire from the left pickup should go to the coil which carries the 1/4 plug wires and obviously the wire from the right pickup should go the coil carrying the 2/3 plug wires.
Edit: Dang Patton, you're fast...
77 KZ 650 B1, 82 GPz 1100 B2.
Last edit: 20 May 2009 14:34 by OnkelB.
- Jack
19 May 2009 17:13
Thank you gentlemen, that's all it was and thanks for your help. Got it running quickly after switching the coil wires.
79 KZ 1075 MKll
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- timebomb33
19 May 2009 19:09
hey jack dont you just love it when it's something easy. did you get the money order yet.
I THINK MY POWERBAND BROKE
- bountyhunter
19 May 2009 21:03 - 19 May 2009 21:04
Jack wrote:
I took about four semesters of statistics and probability, but I have never figured out how something that has a 50-50 chance of going on the wrong way will go on the wrong way 100% of the time......:laugh:Thank you gentlemen, that's all it was and thanks for your help. Got it running quickly after switching the coil wires.
Last edit: 19 May 2009 21:04 by bountyhunter.
