KZ750 ignition timing question.
Re: KZ750 ignition timing question.
30 Sep 2015 06:47 - 30 Sep 2015 06:49
It should be as in the photo by loudhvx. Also, just a note: do not turn the crankshaft by using the smaller timing advancer bolt ---- instead, put a 17mm wrench on the big nut.
1981 KZ650-CSR.
1981 KZ650-CSR.
Last edit: 30 Sep 2015 06:49 by martin_csr.
- Dirty Magic
Re: Re:KZ750 ignition timing question.
30 Sep 2015 07:00
Awesome!
ThanX as always.
Oh, should I have an earth tab or something going to that little red thing, with the brass bolt? It was naked and loos when I popped mine open?
ThanX as always.
Zombie 750.
AKA a 1980 KZ 750 H1 that's spent 80% of its life dead in a bush!
- loudhvx
30 Sep 2015 07:59 - 30 Sep 2015 08:00
That thing is the pressure switch for the oil pressure warning light. It usually has a blue wire (maybe with red stripe) attached to it, and that wire runs all the way up to the gauges to the oil light.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 30 Sep 2015 08:00 by loudhvx.
- Dirty Magic
30 Sep 2015 08:25
Ah, that makes sense, thanX loudhvx.
Looking better already.
Attachment ImageUploadedByTapatalk1443634835.875566.jpg not found
Zombie 750.
- missionkz
30 Sep 2015 09:04
If that advancing mechanism is yours, I would certainly push those 'E' clips off remove the springs, weights and cam, clean rust from those, polish the pins and resemble with a good lube, especially the inside of the cam and shaft..etc
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
- Dirty Magic
30 Sep 2015 09:52
Yep, all the sliding parts have been cleared, cleaned, then cleaned again with a brass brush and wet&dry paper with a little petrol, flushed off with some brake cleaner. All lubed up and reddy to go.
Nothing was moving at all when I started. Lol
Oh and the plug from the pickups themselves had bad corrosion on two pins. So that's had a good seeing to as well.
ThanX again to everyone.
Zombie 750.
30 Sep 2015 11:50
The wiring diagrams show a blue/red wire for the oil pressure switch.
Here's a site w a pdf manual & wiring diagrams. mbsween. bike-night. KZ750L3 . Scroll down & click "The Bible" link.
Note: some of the wiring diagrams are mislabeled in the links: the 1981 Ltd is an H2, the 82 is an H3, & the 83 is an H4.
The following user(s) said Thank You: Dirty Magic
- pete greek1
30 Sep 2015 17:08Are you using JIS screwdrivers ? if you're using Phillips screwdrivers you will ruin all the screwstelefunkin wrote: yep bounty, just cracked it open and that is how it is set up. When i line up the "F" timing mark the flywheel is out almost a quarter of an inch setting off the spark too early.
I got 2 of the screws out but the third is being a biatch. The previous owner must of been in here before and stripped out the screwhead so I can't get a grip to remove. Now i gotta get down to the hardware store and get some kind of bit to pull this out.
Thanks...
Pete
30 Sep 2015 17:50
I mark mine with type correction paint for my old eyes to see better. :whistle:
