Horn Trouble - KZ1000st
- KOOL RYDER
- KZ 650B2 / KZ 1000E
12 May 2009 12:59
Hey Everybody.......
So my horn is not working...
The symptom was no horn, but when I push the switch down I can hear a clicking noise.
I pulled the tank and cleaned the contacts with some sandpaper. Reconnected the wires and still had the same symptom. All lights work so I am wondering what could cause this.
My horn worked until I brought it into the shop to get the cam plugs changed.
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
1978 KZ650B
1979 KZ1000ST
- MFolks
Re: Horn Trouble - KZ1000st
12 May 2009 13:11
The way most Kawasaki's horns are wired is that the horn button gives the horn(s) a ground.
It might be worth the time to upgrade the horns to something louder, using your old horn circuit to power a relay. Here's some idea's from Griot's Garage website:
www.griotsgarage.com/p2p/searchResults.d...y=newArrivals&page=1
- Old Man Rock
12 May 2009 16:38
Down and dirty quick test....
Run a jumper wire from the battery or a good frame ground to the left handle bar control...
Press horn, yes/no worky?
If yes, then have a bad ground to the switch or the left control isn't grounding on the bars well enough...
If not, with the left control open, touch the other side of the switch with the jumper ground... Worky?
Then faulty switch or ground connection to switch input missing, ground not getting through...
With an OHM meter/DVM, does the switch measure continuity when depressed?
I just had this occur on my bike, due relocation of new mirror mounts, lost ground contact via the bars... Wiggle the contact, worky.... Bars are black painted/anodized or what ever the hell they are.... Sand paper to clean metal where the control clamps to the bar, all worky fine now.....
Let us know how it goes....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Qdude
- It is all good.
12 May 2009 17:56
I wonder if the clicking that he hears is a relay?
Maybe there is already another upgraded horn in an its relay is working, but the horns came undone.
77 KZ 650 C1.
77 KZ 650 C1.
77 KZ 650 C1.
- KOOL RYDER
13 May 2009 13:22
I am going to diagnose the issue tonight. It worked really well before going to the shop. It is a SPARTAN horn, I think it is original.
THe horn wires went from a recangular box under the gas tank to the horn. Anyone direct me to a wiring diagram or lay out a diagram for me to refernece.
I know the Ron has a KZ 1000 ST.
1978 KZ650B
1979 KZ1000ST
1978 KZ650B
1979 KZ1000ST
13 May 2009 15:45
Here's a link including a couple of 1980 KZ1000's which may include a helpful wiring diagram.
Navagate to Filebase under KZ Information, go to 1980 models, select bike, and download wiring diagram.
Or just click here > 1980 KZ models
By the way, can test horn function with test wires from the horn terminals directly to battery terminals.
Some horns have a center screw adjustment, while others don't. With center screw adjuster present, just connect horn directly to battery and turn the adjuster screw a little one way and then the other to see if the horn comes alive.
Good Luck!
Good Luck!
13 May 2009 15:51
KOOL RYDER wrote:
The rectangular box may be a relay activated by the handlebar horn button. Whereby full battery power to the horn is provided through the relay.
Good Luck!
... horn wires went from a rectangular box under the gas tank to the horn....
Good Luck!
