Headlight not working... Solved
  • vincentmoy
  • vincentmoy's Avatar Topic Author
07 May 2009 15:01 - 08 May 2009 17:32
#288798
So... so the headlight of my 80 KZ750 is not working. It was fine 2 weeks ago when I bought it. But it has been sitting outside for a week or so and today when I started it I realized the headlight is not on.
I tried to switch between Hi/Lo with no avail. The wire looks good though.
FYI other lights work just fine.
Any ideas?:dry:
1980
KZ750 LTD
Miles: Unknown (speedo cable broke)
Last edit: 08 May 2009 17:32 by vincentmoy.
  • anarki650
  • anarki650's Avatar
Re: Headlight not working
07 May 2009 15:23
#288806
Is the bulb burned out? Did you check the fuse?
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
  • vincentmoy
07 May 2009 15:25
#288807
I haven't checked yet.
But I just found out EVERY lights are not on. But they function.
Also the head light failure light is not on neither.
1980
KZ750 LTD
  • anarki650
07 May 2009 15:27
#288808
Check your fuse box. This should be the first thing you always check if you have lights not working or other electrical failure.
09 Kawasaki ER6n
Omaha NE
07 May 2009 15:30
#288809
Would test voltage on the three-way connector inside the headlight shell where the three prongs at rear of bulb fit into.
If voltage is at the connector but headlight doesn't burn, likely needs a replacement bulb.
Unusual for both low and high beam filaments in the headlight bulb to simultaneously burn out.
Could also check charging voltage across battery terminals to assure voltage regulator is okay and not allowing too much voltage. Look for 12+ volts at idle and 14-15 volts at 4000 rpm.
Good Luck! :)
  • vincentmoy
07 May 2009 15:36
#288810
May I asked where is the fuse box located?:unsure:
1980
KZ750 LTD
  • MFolks
  • MFolks's Avatar
07 May 2009 16:11
#288820
On some of the larger older 4's it will be in a holder with several fuses under a translucent cover under the seat or nearby.
On some bikes it might be in a small black case with the word "Fuses" I'd imagine if the fuse is bad/broken a good auto parts store will have replacement 10-20 amp AGX fuses (they are 1" long, anything else won't fit the clips).
  • vincentmoy
07 May 2009 16:21 - 07 May 2009 16:22
#288825
Ok, just looked @ the fuse box and indeed one of the fuse burned out (the red-blue wire one)
I swapped a good fuse (the one in the middle) into it and now the tail and the front turn signal light would stay on.
BUT
No headlight still:(
1980
KZ750 LTD
Last edit: 07 May 2009 16:22 by vincentmoy.
07 May 2009 16:45
#288830
vincentmoy wrote:
Ok, just looked @ the fuse box and indeed one of the fuse burned out (the red-blue wire one)...
BUT
The blue wire end clip and metal part of fuse look so badly corroded there may not be electrical contact between them whereby no current is flowing through the fuse and would perhaps not flow through a new uncorroded fuse. Imo, both a fresh blue wire end clip and fresh fuse should be fitted.
The red wire end clip doesn't look all that great either.
The white wire end clips look okay.
Regardless, for the headlight to light, voltage is required at the three piece connector where the bulb prongs fit into (as earlier mentioned).
Good Luck! :)
  • vincentmoy
07 May 2009 16:55
#288837
Where can I get those clips? Just a normal auto store?
1980
KZ750 LTD
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
07 May 2009 17:45
#288879
If there is enough of the origional metal clip left, you can just brush it up real good with a steel wire brush, BBQ brush, whatever. The end result should be nice an shiny surfaces on both the fuse ends and clips.
Then use some di-electric sparkplug grease (or vaseline :P )on the connectors before you snap it all back together.
Cheers.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • saxjonz
  • saxjonz's Avatar
  • KawboyZ
07 May 2009 18:02
#288889
Have you even tried to see if jeff stocks them at z1enterprises.com? If not and you have to replace those wires for sure go a different route with the square fuses which of course would mean that you would have to do some modding. But at 21 bucks or whatever these sell for you would be ok to replace it.
Although the wires don't look burnt so maybe you will get off with just cleaning the contacts really nice and using that lubricant/grease and be done with it.
79 LTD B3
