Headlight not working... Solved
  • bill_wilcox100
  • bill_wilcox100's Avatar
Re: Headlight not working
07 May 2009 19:56 - 07 May 2009 20:02
#288920
See Z1 Ent
"Fuse Assembly Kawasaki KZ650 KZ900
26004-035
OEM: 26004-035 -
Fits Kawasaki KH250 KH400 KH500 KZ1000A1-A4/B1-B4/C1-C4 KZ200A1-A2 KZ250D1/D2/L1 KZ305A1/A2/B1-B3 KZ400/A/B/C/D/H/S KZ440A/B/D KZ650B/C KZ750B/G/M KZ900 S1 S3
$30.50"
Best of success. :)
PS
1- You will need a Maintenance ASAP.
2- Add your year, model and location to your signature to get the best replies.
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Last edit: 07 May 2009 20:02 by bill_wilcox100.
07 May 2009 20:03 - 07 May 2009 20:07
#288925
No eBay APP ID and/or Cert ID defined in Kunena configurationThis might be considered until the genuine article becomes available.
It's ebay item 350198150591.
Touted as a CD version of the FSM.
Good Luck! :)
Last edit: 07 May 2009 20:07 by Patton.
07 May 2009 20:22
#288941
From KZR Filebase under KZ Information, go to 1980, then to KZ750H, then download the parts diagrams and other info.
Perhaps these links may work.
Click here > Filebase Link A
Click here > Filebase Link B
Good Luck! :)
  • vincentmoy
  • vincentmoy's Avatar Topic Author
08 May 2009 04:05
#288991
I actually got a FSM on ebay but the media shipping takes forever to get it up Alaska:(
1980
KZ750 LTD
Miles: Unknown (speedo cable broke)
08 May 2009 06:47
#289016
On the Z1 and KZ900 headlights, there are two panhead screws at 8 o'clock and 4 o'clock positions through the shell behind the rim which screws hold the headlight and shell together. Removing the screws allows the headlight assembly to be pulled away from the shell. Be careful not to drop the assembly or allow it to fall, because the only thing holding it could be the plastic connector where the bulb fits. Should be able to disconnect at the connector and set the assembly aside during testing.
There are three wires going into the connector, and three holes in the connector to accomodate the three prongs on end of the bulb. My thinking is maybe the bulb is just blown out and that only a new bulb is needed.
The main idea is to assure that electric current is getting to the connector when the ignition switch is turned ON. One connector hole is ground, another is for dim and the other is for bright. Just probe the holes with voltage meter test wires.
Glad to see an FSM is on the way which imo is essential to properly care for and enjoy the bike.
Here's the headlight diagram as shown on kawasaki.com. On the 1980 KZ750-H, there might be more than 2 panhead screws holding the headlight assembly inside the shell. Should be easy to see when actually looking at the bike.
Good Luck! :)
[Click on image for better view]
  • vincentmoy
08 May 2009 12:11
#289058
Here is the only 2 bolt I can find that is holding the headlight assy.
1980
KZ750 LTD
  • vincentmoy
Re: Headlight not working... Solved
08 May 2009 17:34 - 08 May 2009 17:35
#289151
Problem solved. It is the bad contact @ the middle fuse. I may just clean it up and get a new fuse and call it good:laugh:
Finally the manual arrived!!! :cheer: :cheer:
1980
KZ750 LTD
Last edit: 08 May 2009 17:35 by vincentmoy.
