MSD or ACCEL igniton
- Darkangel
22 Apr 2009 15:15
Is there msd or accel ignition components i can use on my KZ 1100
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
- kano
- Not Another Bloody Limey!
Re: MSD or ACCEL igniton
22 Apr 2009 15:28
i just bought a dyna 2000 kit from z1e for my bike
it is reportedly the best dude go to www.dynaonline.com/skins/default.aspx
i have been running accel coils and leads for the last couple of yrs with no issues.
- MFolks
22 Apr 2009 15:56
If you're good at electrical circuit building, one of the members here has used off the shelf GM modules for a number of years.
www.geocities.com/loudgpz/GPZgmHEImod.html
- timebomb33
22 Apr 2009 16:59
dyna ignitions are easy to get and work excellent but so doesn't your stock ignition system. unless you need to update coils or need a two-step type box i'd stay with stock.
I THINK MY POWERBAND BROKE
- Darkangel
23 Apr 2009 12:09
Well considering that I have no spark right now going to my plugs...i've got some ignition problems..and i rather go with electronic ignition.
- jordan
23 Apr 2009 12:14
i am using a dyna s 2000 full ignition system and it works great. Easy to use and you will probably never have to mess with it again.
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- Darkangel
25 Apr 2009 09:43
what about the dyna 2 systems....the dyna 3000 does that replace rectifier, and all of your ignition stuff...
- MFolks
25 Apr 2009 10:09
My understanding is what you're calling a rectifier is actually the IC Igniter(it gives the coils a ground firing the sparkplugs). The Dyna S replaces this with everything under the points cover doing the work of the old parts.
- 79MKII
- Love Them Kaws!
25 Apr 2009 10:57
I've been running an MSD MC-1 for about 15 years now and it's awesome. The plugs spark multiple times per stroke (Multiple Spark Discharge, MSD). I bought it mainly for drag racing so I could add a 2 step. They're great units but unless you need the 2 step a regular dyna S conversion is probably the best / easiest / cheapest solution. It pretty much bolts right on by replacing your points set up. Good luck.
The Kaw List:
- Darkangel
25 Apr 2009 14:44
I will really be doing a lot of street racing...so whatever is the cheapest yes...
- timebomb33
25 Apr 2009 14:49
not with a kz 1100 shaft drive you won't.
- loudhvx
25 Apr 2009 15:19
According to Dyna, the coils for use with a Dyna S are 3-ohm minimum. Don't know what year 1100 you have, but if it came with electronic ignition, you'll have to get new coils to use the Dyna S. However, others have used lower resistance coils with success, but I don't think they used them on a permanent long-term basis.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
