'80 kz550 ignition tests
- 508_ponshock
28 Apr 2009 11:40 #285999
by 508_ponshock
'77 kz1000 (in Wisconsin)
'80 kz550 (in Washington)
Replied by 508_ponshock on topic '82 kz550 ignition tests
Hello again, I have my ohm-meter working, not sure why that was so complicated, and I have received a complete plate with pickup coils and wiring from an e-bay auction.
Resistance measurements on my cycle support the bad 1&4 pickup coil. On the used part that I just received resistance readings are 428 Ω and 430 Ω, is this too low? Seeing as the used part is complete is it preferable to replace the whole unit or just the components that are non-working? And is it just a simple screw-out screw-in swap with no timing adjustments necessary?
Perhaps for posterity: the used part is from a 1982 KZ750 Spectre and appears to be an exact match including the length of the wire.
- loudhvx
- Thank you received: 1616
28 Apr 2009 14:00 #286021
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic '82 kz550 ignition tests
I would swap out the whole plate. The magnets have a particular orientation which can be messed up if you take the whole thing apart.
420 to 430 ohms should be fine. It may just have been a change in the manufacturing tolerance, or a slight alteration on the construction.
If your timing plate doesn't have slots for the mounting screws (which was common), then the timing is not really adjustable. In order to get it just right (if you're really picky), though, it is a common mod to elongate the holes into slots.
If you do dissassemble it for some reason, there is a thread that explains how it should go back together.
kzrider.com/index.php?option=com_kunena&...d=4&id=134605#134612
1981 KZ550 D1 gpz.
Other links.
- 508_ponshock
30 Apr 2009 12:43 #286541
by 508_ponshock
Swapped the plate, checked the spark, cleaned the gas tank, and drained the float bowls and it fired right up. Awesome! Rode it around a little but the tabs are in the works so I am still adjusting some things on the bike before I start riding it a lot. The person I bought it from hasn't had it registered for two years so there are some minor adjustments to make. Thanks for your help! I've attached an image file of the bike.
- Russ Jackson
30 Apr 2009 12:54 #286542
by Russ Jackson
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
Replied by Russ Jackson on topic '82 kz550 ignition tests
Nice job! This is a great site is'nt it? This site has saved me tons of time and money. Good Luck with your new bike. Looks like a fun one. Don't think it will be the rush that the KZ1000 is. Got a picture of it?...Russ
- 508_ponshock
30 Apr 2009 12:59 - 30 Apr 2009 16:17 #286544
by 508_ponshock
Replied by 508_ponshock on topic '80 kz550 ignition tests
Unfortunately I don't have a picture of the 1000 here in WA. I hope to get one this June when I'm home for a few weeks in WI.
Excellent site! The 550 was actually pretty stripped down when I bought it for $175, no handlebars, clutch perch, headlight, etc. A lot of time and a lot of help from this site and I think it will turn out to be a pretty good bike.
Last edit: 30 Apr 2009 16:17 by 508_ponshock.
