starter
  • Bdog
  • Bdog's Avatar Topic Author
  • Sweep the leg johnny!!!
starter
28 Mar 2009 11:37
#276089
Hit the start button, solenoid clicks, and I have power at the starter lead. What next? Just put 810 kit on. Wouldthat overpower the starter?
Brandon
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
  • MFolks
  • MFolks's Avatar
Re: starter
28 Mar 2009 11:47
#276092
Battery fully charged, Battery cables all clean and tight,Starter Solenoid cables clean and tight, Negative Battery Cable to Engine clean and tight?
If the above are in good shape, try putting something conductive(like a screw driver) across the heavy terminals on the starter solenoid and see if the starter turns, if not the starter needs rebuilding with new brushes or bushings.
This is a website for starter repair parts:
www.cyclewareables.com/pages/street_star...kits/startmtrkit.htm
  • Bdog
Re: starter
29 Mar 2009 06:02
#276305
Somehow the starter was bound up. Got it starter last nite after a few beers, and man it sounds evil!!!
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
