cca's for 810 kit
- Bdog
- Sweep the leg johnny!!!
cca's for 810 kit
28 Feb 2009 05:14
Has anyone done the 810 kit on a 750 and had problems with the stock battery or starter? Solutions? Thanks
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
- Mark Wing
Re: cca's for 810 kit
28 Feb 2009 10:11
I use the kickstarter.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- Samwell
28 Feb 2009 11:31
Bdog wrote:
As long as your not bumping the compression too much, then the stock setup should be fine. It never hurts to make sure your battery is good and the connections to the starter are clean and tight.
There was a thread around here somewhere about swapping a Honda CB900 starter into the 1000cc kz's. Just search for 'honda starter' Apparently, it'll fit wih only minor mods. The stock kz starter is 0.6 kW and the Honda part is 0.8 kW, so it can spin things harder/faster. If your bike uses the 1000's starter then this is the mod for you.
hope this helps...Sam
