little screws for points - where to find??
  • jzanutto
  • jzanutto's Avatar Topic Author
23 Dec 2008 10:11
#254281
I'm just getting into this 78KZ that I picked up, and I popped off the right side cover to check the points. whoever tightened those screws last time torqued them up good!!! were talkin like 800 foot pounds! They are all messed up.
where can I get some more of those little screws? or what size are they, maybe I can get some little allen-head ones?
1978 KZ650B 2004 BMW R1150RT
  • timebomb33
  • timebomb33's Avatar
Re: little screws for points - where to find??
23 Dec 2008 16:52
#254347
they are 4mm and yes you should be able to get them from any decent bolt supply place in allen head the reason they are so tight is they were probably installed with an impact driver and possibly itstalled with loctite on the threads. if you want to get the factory philips screws out with no hassle buy you self a good quality impact driver or be prepared to replace all the screws in your bike when the heads get messed up with a regular screwdriver.
I THINK MY POWERBAND BROKE
  • jzanutto
24 Dec 2008 02:20
#254407
yeah I have an impact remover that has worked on every other bike Ive worked on, but these are tighter than any other I've ever seen.
the left side sprocket cover bolts are broken off as well, I've been getting those out one at a time over the last 2 days..:angry:
  • wiredgeorge
  • wiredgeorge's Avatar
24 Dec 2008 06:55
#254427
I would think these screws are JIS and M3. JIS screws have a slightly different type of slot than does an SAE Phillips head screw and you WILL strip them easily if you don't use a JIS screwdriver. You will NOT be able to find JIS driver bits... use a JIS #1 screwdriver to remove these or most of the screws on a carburetor. This type screwdriver is most likely sold in a place where you can buy repair parts for copying machines or in hobby stores as most small Japanese model engines use them. JIS stands for Japanese Industrial Standard and they are identified by a small dimple in the head... they have JIS screws but also JIS bolts and other fasteners but the slotted screws are the only bits that require a specific screwsdriver.
