Dyna Coils Installed Images???
  • Old Man Rock
  • Old Man Rock's Avatar Topic Author
23 Nov 2008 06:34
#248964
Anyone have some exploded view images of the Dyna coils installed in their frames?
Reason I ask... See image where orientation is up and facing forward on the secondary.
Thanks,
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Old Man Rock
Re: Dyna Coils Installed Images???
23 Nov 2008 06:48 - 23 Nov 2008 06:49
#248967
oops!
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 23 Nov 2008 06:49 by Old Man Rock.
  • bill_wilcox100
  • bill_wilcox100's Avatar
23 Nov 2008 07:51 - 23 Nov 2008 07:51
#248974
OMR, this is how I installed mine. Note that the coils shown are the OEM's. I have Dyna 3 Ohm Green now.
Best of success. :)
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Last edit: 23 Nov 2008 07:51 by bill_wilcox100.
  • MFolks
  • MFolks's Avatar
23 Nov 2008 12:58
#249012
I do not have an image, but I installed my green Dyna coils on my 82 GPZ1100 B2 facing down with the sparkplug leads to the rear.
  • timebomb33
  • timebomb33's Avatar
23 Nov 2008 13:29
#249017
i always mount my coils on stock frames up and plug leads forward and on modified frames[drag chassis] ialways mount them up front below the steering head out in the elements where they are easy to get to in case of problems.
I THINK MY POWERBAND BROKE
  • Old Man Rock
23 Nov 2008 16:19 - 23 Nov 2008 16:21
#249026
Thanks for the replies guys...
As can be reviewed in the image, I figured out why they stated up and forward... Otherwise, the coil boots hit the frame and you would end up with weird bends on the plug wiring...
As for the mounting, I had to install the nut, then the spacer from OEM configuration. This provided enough clearance all the way around.
I put heat shrink on the spacers to keep ignition spark from jumping, also helps in case moisture seeps around the coils. I also put E6000 on the ignition to coil terminations, prevent high arc spark and moisture...
7mm high suppression spark plug wires were installed...
For the ignition to coil terminations, I used the OEM cable harnesses and tined/solder the ring terminals. Use heat shrink and rubber tape for added protections.
All from, you guessed it, our very own Z1 Enterprises...
Tomorrow, install the ignition plate... Should have the heads by end of next week.
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 23 Nov 2008 16:21 by Old Man Rock.
  • MFolks
  • MFolks's Avatar
23 Nov 2008 19:25
#249057
I discovered the iron laminations will rust after exposure to the moisture in the air. To stop this problem I used some Glyptol high temperature varnish painted over the laminations. GC electronics sells it and I'd imagine it's available locally from the nearest electronic supply stores.
  • HerrDeacon
  • HerrDeacon's Avatar
03 Apr 2009 11:53
#278079
I was looking for pics of installed Dyna coils and came across this great thread. Just wondering where you guys got the spacers that go on the bolts? Can you pick them up at hardware stores?
  • dutchz
  • dutchz's Avatar
03 Apr 2009 13:14
#278101
Yeah I think I got some plastic spacers at Ace.
1974 Kawasaki Z1
Stock front hub and rear axle.
  • kano
  • kano's Avatar
  • Not Another Bloody Limey!
03 Apr 2009 13:16
#278102
did i miss the part where you install the pickups?
i just got these looking for some tips. ;)
  • Old Man Rock
03 Apr 2009 15:51 - 03 Apr 2009 20:26
#278152
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 03 Apr 2009 20:26 by Old Man Rock.
  • kano
  • kano's Avatar
03 Apr 2009 17:09
#278171
thx dude! ;)
