dyna or accel
- Bdog
- Sweep the leg johnny!!!
dyna or accel
16 Nov 2008 06:07
I a set of each and the accels are already set up and wires cut and stuff, Is there any difference between the two?
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
- PLUMMEN
Re: dyna or accel
16 Nov 2008 07:57
whats the ohms on eachof them?
- Bdog
Re: dyna or accel
16 Nov 2008 08:36
3 ohm
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
- timebomb33
Re: dyna or accel
16 Nov 2008 12:12
then there won't be a problem i use both myself on diferent bikes
I THINK MY POWERBAND BROKE
- Bdog
Re: dyna or accel
23 Nov 2008 06:04
Right, but is there a reason to use one over the other? Is there a better of the two?
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
- Old Man Rock
Re: dyna or accel
23 Nov 2008 06:10
Are you planning on switching to electronic ignition?
If so, Dyna 3 or S series ignition?
Then stick with the Dyna for the coils and ignition are somewhat matched for your bike model...
Outside of that, probably comparable in performance...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Old Man Rock
Re: dyna or accel
23 Nov 2008 06:50
Theres also else to think about if not going with electronic ignition. This excerpt is for Dyna coil installation, not sure about Accel coils....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- wiredgeorge
Re: dyna or accel
24 Nov 2008 07:02
It makes no difference whether you install the Dyna or Accel coils. The main difference is that the mounts holes are offset about 3/4" too wide for the Accel so you will have to use one bolt/nut and one wire tie where the Dyna holes line up for a KZ bracket and you can use two bolts.
- steell
Re: dyna or accel
24 Nov 2008 18:24
Accel coils bolt straight on the 76-80 KZ750 twins and the 83-85 GPz750's, while the Dyna coils require some work to fit. On the 650's the reverse is true, Dyna's bolt on, Accel don't.
I don't have a clue about other years/models, but I guess I'd better start thinking of what to use on my 80 KZ750E project.
- Bdog
Re: dyna or accel
25 Nov 2008 14:28
Yeah I thought it was in my sig. but I do have a dyna S ignition, but also the 80 750 motor which is in my sig., has factory idi. Basically my question was answered, the actual coils are roughly the same for an aftermarket, high performance coil. Thanks for the input fellas. Hope all your winter projects are going well.
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
- flht1997
Re: dyna or accel
25 Nov 2008 14:36 - 25 Nov 2008 19:04
You can mount the Accel coils sideways on the 650 with the supplied brackets. the rear coil is very close to the valve cover but they will fit without any modification.
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
89' BMW R100RT
06' KLR650
Last edit: 25 Nov 2008 19:04 by flht1997.
