where is the damn hi-beam switch?
- un_Love
03 Oct 2008 23:33
may sound kinda stupid, but i just got my 83 KZ750 LTD, and when the lights are on, the hi-beam light is on. can't figure out where the switch is. thanks.
1983 KZ750-K LTD Belt Drive
- drmadd95
Re: where is the damn hi-beam switch?
04 Oct 2008 01:11
Is there a switch on the left handlebar control that says Hi and Low?
1979 KZ650 B (Main Ride)
1978 KZ650 D1 (sold)
1982 KZ750 (parts bike)
- un_Love
04 Oct 2008 09:15
not that i've seen..
04 Oct 2008 09:24 - 04 Oct 2008 09:25
Last edit: 04 Oct 2008 09:25 by Patton.
- bill_wilcox100
04 Oct 2008 10:39 - 04 Oct 2008 12:57
un_Love, if you have the '83 KZ750-4 LTD chain drive this is the Kawasaki handlebar diagram. See the left side switch gear assembly.
You should find a Hi/Lo Switch but not ON/OFF Switch. If not, a PO has changed something on this bike.
Best of success.
PS
Add your year, model and location to your signature to get the best responses... and it's considered friendly too.
Bill
Best of success.
PS
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Upgrades:
Montreal, Canada
Last edit: 04 Oct 2008 12:57 by bill_wilcox100.
- un_Love
04 Oct 2008 10:56
Ah, I see. Must have a burned out low beam, then. Thanks for the advice, and the community here seems great.
Will upload pics of the bike later today.
- MFolks
04 Oct 2008 11:29
If your bike has the reserve lighting device it will automatically switch to what ever lighting beam has not burned out. I.E. if low is out or hi is out it electronically selects the other good filiment.
It's a small box with six wires going to it usually on the left side below the seat.
- un_Love
04 Oct 2008 12:30
well, i wasn't aware that the switch was a low/hi, assumed it was on/off. first bike, like i said.
no light at all in the other position.
another stupid question, i suppose.. maybe i should start another thread..
is the brake light supposed to engage when the front brake is applied? because mine only works on the rear brake..
sorry, i'm a first timer. also can't figure out how to use the kick start. it's a fun learning process, though.
pics attached, as promised. seat's rough, and paint's faded, but clean as hell otherwise. runs like a demon.
- MFolks
04 Oct 2008 13:13
If there is a switch controlling the brake lights (other than the right foot pedal) it would be in the right lever housing next to the master cylinder for the front brake.
When the lever is pulled back you should hear a click from the switch(the previous owner may have removed the switch)
As for the kick start lever operation, turn on the gas, make sure the transmission is in neutral,pivot out the kick start lever,apply a little choke,and step firmly and rapidly on the lever. It might take a few kicks to start the bike, but if it is good tune no more than three or four to get it running.
- bill_wilcox100
04 Oct 2008 13:15
un_Love, you may only need a new light.
The rear light should come on when the front break in is used. If not, troubleshoot the pressure switch and or associated wiring.
To use the kick starter turn the fuel petcock ON/PRI, put the choke ON, go into neutral, do not touch the accelerator, do not pull the clutch lever in and then crank the engine. It should now start. Do not leave the ignition switch ON when the engine is not running as this may over heat your coil(s).
Seat is no problem. Seat covers are available from Saddleman and others for most models. I got mine through Z1 Enterprises. What a difference.
Best of success?
PS
I was just in Littleton and Golden last week. Nice riding area.
BTW, check under your seat for the original Operator's Manual. Also, get a Service Manual... you will need it and you'll thank yourself.
Bill
Best of success?
PS
Bill
Upgrades:
Montreal, Canada
Upgrades:
Montreal, Canada
- un_Love
04 Oct 2008 13:41
you guys are the best, thanks. i'll check the wiring for the brake, and the low beam is indeed burned out.
found the manual under the seat, what a difference.
thanks again, this board is invaluable.
- un_Love
04 Oct 2008 13:55
found two hanging wires, guess the switch is gone. where can i get one?
