where is the damn hi-beam switch?
Re: where is the damn hi-beam switch?
04 Oct 2008 15:00 - 04 Oct 2008 18:34
#240146
un_Love wrote:
found two hanging wires, guess the switch is gone. where can i get one?
Maybe the front brake light switch isn't missing, but just hidden in the area behind the headlight shell (where the two loose wires could reach it). If so, it's anybody's guess why the wires were pulled off the switch and not re-attached. Maybe the rear brake light stayed on all the time. Who knows. Maybe the Shadow knows.
Anyhow, the switch is about as big around as a nickel and should look something like this.
Good Luck! :)
EDIT -- The 1983 KZ750 twin uses a uses a different switch. (See later posts).
Last edit: 04 Oct 2008 18:34 by Patton.
  • un_Love
  • un_Love's Avatar Topic Author
04 Oct 2008 15:36
#240151
hmm.. here's a pic. don't know how these would reach anywhere else..
1983 KZ750-K LTD Belt Drive
04 Oct 2008 18:27
#240168
un_Love wrote:
hmm.. here's a pic. don't know how these would reach anywhere else....
You are correct :cheer: and I was wrong :( about the front brake switch location on the 1983 KZ750 twin, which according to Kawasaki.com parts diagram does indeed have the switch integral to the master cylinder.
Hope a replacement switch is available.
Good Luck! :)
  • un_Love
04 Oct 2008 18:41
#240169
having trouble rationalizing how in the hell this thing actually works, as it's not connected to the lever at all.. does the pressure sensing come from the brake itself, or elsewhere?
04 Oct 2008 19:01
#240176
Here's the parts diagram from Kawasaki.com showing #27010 as the brake switch.
Am uncertain as to exactly which brake function is supposed to activate the switch. :unsure:
[Click on image to enlarge view]
