Electronic Tacho Conversion
- cherrymetal
06 Aug 2008 04:12
Has anyone replaced their mechanical tacho with an electronic one? I have a GPz750 engine in my '77 KZ650, which has no worm gear for tacho drive, so I need to fit an electronic one, but I want to keep the existing tacho housing. Has anyone done this, how easy was it?
I have a GPz550 instrument panel in bits, could I use the tacho from this, how do I wire it in etc.??
_____________________________________________________
1977 Z650 (WIP - GPz750 Engine, RF400 Wheels & brakes, Bandit 600 Forks, Zephyr Swingarm)
1997 ZRX1100 - Stock - for now!(except for Hindle header with Micron carbon can)
1988 NTV600 Revere - Stock (work hack!)
Re: Electronic Tacho Conversion
06 Aug 2008 07:37
here is a link to an affordable tach,speedo(plus other features)that has been recomended by racers and special builders.
trailtech.net/motorcycle_vapor_kits.html
hth,leon
hth,leon
- mariozappa
06 Aug 2008 08:16
acewell.co.uk/en_uk/motorcycle/index.htm
I plan on getting the ace-2803 AB
They are expensive, but I like em!
1977 KZ650C1
and the KZ650/KZ750 Conversion
- cherrymetal
06 Aug 2008 23:40
No, this isn't what I'm after, I want electronic not digital. It must fit in the Z650 tacho housing, and look the same... Anyone done this?
- steell
07 Aug 2008 05:49
Never done it, but take a look at 81-83 KZ1000J and 81-82 KZ1000K (LTD) gauges, I think they are about the same size and both have electronic tachs.
