aftermarket speedometer
- badr0bot
Re: aftermarket speedometer
21 Sep 2008 15:10
I couldn't find it on JP cycle. I ordered mine from chopper surplus.
www.choppersurplus.com/np/instruments/ds/mini_speedo.html
87 KZ1000 P1
21 Sep 2008 19:42
what did you end up having to do about the fittings for the cable?
post some pics of your bike.
how did you lower it?
speedo looks cool,btw!
- badr0bot
22 Sep 2008 17:47
Hey Banshee, The fittings fit. Same threads as the original speedo. No mods necessary.
The previous owner took off the shocks and welded a plate on each side from the frame to the swingarm. not too pretty but the saddle bags hide it. Some pics posted here.
www.flickr.com/photos/badr0bot/sets/72157607437701744/
87 KZ1000 P1
23 Sep 2008 06:38
i gotcha it is rigid now.so the speedo was a pretty easy install?
- dfinnegan71
18 Apr 2012 19:21
So was it the 2240:60 ratio? I only asked because I just installed an aftermarket and it must be a 1:1 ratio. I was showing 80mph but probably going half that, and the OD read 3.2 mile and I was a mile or so away from house at most. Anyway time to ebay that one and get a correct ratio speedo.
1981 GPZ 550 mild custom
- badr0bot
18 Apr 2012 19:35
Yes, it was the 2240:60 ratio. Good luck.
87 KZ1000 P1
- mark1122
- Keep twisting it
20 Apr 2012 17:47
what about your wheel size? it also needs to be the same size as the donor bikes.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
