bike dont hold a charge?
  • kustompup93
  • kustompup93's Avatar Topic Author
22 Apr 2008 12:17
#208262
its an 81kz550c i have 2 out the battery tender/charger on it every night 2 fully charge the battery. anyone know why my bike wont recharge itself? is the rectifier bad or the magneto? need help!
  • Qdude
  • Qdude's Avatar
  • It is all good.
Re: bike dont hold a charge?
22 Apr 2008 12:33
#208270
Take the battery in to get it checked.
77 KZ 650 C1.
77 KZ 650 C1.
  • kustompup93
23 Apr 2008 12:29
#208493
my battery seems 2 be fine, so wat else would it be? the rectifer? or magneto?? something?? need help
  • BSKZ650
  • BSKZ650's Avatar
23 Apr 2008 12:35
#208495
you need to put a volt meter on the battery when it is running to see if it is charging or not, that will be the starting point
77 ltd1000, current rider
76 kz900, just waiting
  • bountyhunter
  • bountyhunter's Avatar
23 Apr 2008 14:18
#208507
Easy way to test the battery: let it charge on the tender until it's topped off. Put a volt meter on it and crank test it: pull your spark plug wires off the plugs and crank the starter. A good battery will hold 9V or higher under starter crank test (higher is better).
If the battery is good and you get no charge, it has to be the rectifier/regulator assembly or the magneto assembly.
  • OKC_Kent
  • OKC_Kent's Avatar
23 Apr 2008 16:46 - 23 Apr 2008 16:48
#208539
To build on to what BSKZ650 wrote:
Quoted below from the Electrosport site, hope it helps.
"Any well working charging system on a modern bike will produce a voltage over the battery terminals in between 13.5V DC and 14.5V DC, over the entire rev range. When you suspect a fault in the system, this is the first thing to check.
When you find that there is a problem, keep in mind that the number 1 problem with any charging system are bad connections."
www.electrosport.com/technical-resources...lt-finding-guide.php
Cashion, OK
78 KZ650 B2 85,000+ miles
Last edit: 23 Apr 2008 16:48 by OKC_Kent.
