Taking the electrical plunge.
  • typhoon
  • typhoon's Avatar Topic Author
29 Jan 2006 02:55
#20350
Hi all, I'm after a wiring diagram for a combined regulator/rectifier Z650, or if one has been put up hee somewhere, post me a link perhaps.
Going more modern on my bike after confirming a dud rectifier.
Regards, Andrew.
gpzrider.com/
For all your air/liquid cooled GPZ fun!
  • DanOz7Five0
  • DanOz7Five0's Avatar
Re: Taking the electrical plunge.
29 Jan 2006 07:17
#20365
kzrider.com/component/option,com_docman/...ew/gid,103/Itemid,5/
If this works there is one in the filebase. That link should take ou there, if not just search the filebase under the Community tab for wiring diagram.
  • BSKZ650
  • BSKZ650's Avatar
29 Jan 2006 19:17
#20447
if that dosent work u2u me and I will fax you any pages you need from the book I have
77 ltd1000, current rider
76 kz900, just waiting
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
29 Jan 2006 19:47
#20450
Here's a B1 Wiring Diagram. The C1 has the Hazard Switch, relay and wiring that's missing in this one.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
29 Jan 2006 20:01
#20453
Ooops. You wanted the combined reg/rec one. I saw your signature and got mixed up. Here's a dia. with the combined:
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • loudhvx
  • loudhvx's Avatar
29 Jan 2006 22:30
#20468
If it's really only the rectifier, you can make one. It's not pretty, but it should work.
Post edited by: loudhvx, at: 2006/01/30 01:32
Arrgh! Freakin' image limits!
Post edited by: loudhvx, at: 2006/01/30 01:34
Try this:
kzrider.com/component/option,com_docman/...oc_download/gid,276/
Post edited by: loudhvx, at: 2006/01/30 01:41
  • typhoon
29 Jan 2006 23:24
#20471
Thanks for that guys. I considered building a rectifier, but couldn't find the bridge thingies locally, plus I would still have had that ancient voltage regulator in the back of my mind.
I also found out today my battery goes flat all by itself, sitting on the bench for 12 hours after fully charging it. How wonderful!:woohoo:
Regards, Andrew.
gpzrider.com/
  • 69goat
  • 69goat's Avatar
04 Feb 2006 15:10
#21486
do you have a wiring diagram for a 76 kz900 z1
  • typhoon
08 Feb 2006 00:24
#22369
O.K, so I have a combination Reg/rec off a GPX 250. I know the three yellows are from the alternator, so if I connect the brown(switched 12v?) and black(ground?) to the same coloured wires that only leaves a white/red coming out if the new regulator, so where should that go?
The new reg/rec is a Kwaka part # SH530-12
9.N
Regards, Andrew.
gpzrider.com/
  • Sorf
  • Sorf's Avatar
08 Feb 2006 02:34
#22371
Exactly what I was thinking!
  • loudhvx
  • loudhvx's Avatar
08 Feb 2006 15:15
#22538
9.N
Regards, Andrew.
That goes directly to the battery. Usually it goes to where the positive battery cable connects to the starter relay.
You may want to put a temporary, in-line, 30 amp fuse on the wire before connecting it in case the wiring is different with that model.
You are right about the black (I would have expected a yellow or white stripe on it), and brown wire.
Make sure that brown wire gets battery voltage any time the ignition key is on. If that brown wire loses voltage, the regulator does nothing and can fry the whole bike (when running).
  • typhoon
08 Feb 2006 23:49
#22667
Thanks for that. If you are ever in Australia, I owe you a beer!
Regards, Andrew.
gpzrider.com/
