Taking the electrical plunge.
  • fergyfer
  • fergyfer's Avatar
Re: Taking the electrical plunge.
09 Feb 2006 13:06
#22752
Does that mean you'll buy him 3 beers if he comes to Australia?:)
  • typhoon
  • typhoon's Avatar Topic Author
09 Feb 2006 23:19
#22874
I think my computer had a bit of a fit! Three beers it is! B)
Regards, Andrew.
gpzrider.com/
For all your air/liquid cooled GPZ fun!
  • loudhvx
  • loudhvx's Avatar
10 Feb 2006 10:42
#22942
Regards, Andrew.
Right on !
  • typhoon
10 Feb 2006 22:47
#23077
The transplant was a success! I now have a full volt higher across teh rev range, a healthy 13v at 1000 rpm and just on 15v at 4000, where it tops out. With the headlights on, take off a half volt or so. The voltage is also a bit more stable too.
I took the opportunity to clean up all the wiring around the battery area, someone a long time ago, who knew very little about electricity, had made a huge birds nest in there! Now it's all neat, and I have 5 fuses I can actually find and reach! I also found an earth wire that wasn't connected to anything, could explain the couple of times I've had smoke issues and partly melted ground wires here and there!
Is there any reason I shouldn't leave the fuses in the reg/rectifier curcuits?
Regards, Andrew.
gpzrider.com/
  • loudhvx
  • loudhvx's Avatar
11 Feb 2006 18:15
#23224
excellent. you can leave the fuse in but make sure it stays clean and the connections are good or they could melt. See if it will work with a 20 amp fuse. That's probably closer to what it should be. If you use a Dyna ignition, it may need to be 25 amps.
Post edited by: loudhvx, at: 2006/02/11 21:17
