Kz1000 single seat rail...help!
  • noremorse
  • noremorse's Avatar Topic Author
09 Feb 2008 22:51
#193719
Was up everyone? I need to pick the brains of all you kz freaks!I am olmost done with my rail with a kz 1000 powerplant.I am cunfused on what i need to make the motor run in my frame,,I believe that the motor is newer than a 80' but im not sure.It has no points it looks to me that it has a cdi (2 magnets with 2 wires going to both) i have a set of dyna coils,Dont have a clue if they will work,,will i need a brain to make spark? I have built one other buggy with a kz650 but i had the frame and all the stuff from the bike,,it was still tricky!,,i will post some photos of the beast tomorrow,,,does anyone have a simple diagram to wire a kz motor to run out of the frame? anyways you folks have helped me with my other rail so much i have returned!,,,any info will be awsome! thanks ..Raen Gregory Phx.Az
Post edited by: noremorse, at: 2008/02/10 17:24
Post edited by: noremorse, at: 2008/02/10 18:18
  • Zedone
  • Zedone's Avatar
Re: Kz1000 single seat rail...help!
10 Feb 2008 07:42
#193776
Hi Raen, I think if you have the original wiring harness for that specific bike it will be easiest way to get your project up & running. You can also use it for any lighting or electrical needs you want to have in addition. There shd. be a wiring diagram in the "KZ Information" tab at the top of the page. If not someone on this board might have one. Regards, Doug
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
  • noremorse
10 Feb 2008 14:20
#193829
thanks for the input but my harness is barely there.,,ill look for the diagram u spoke about,
Post edited by: noremorse, at: 2008/02/10 17:22
Post edited by: noremorse, at: 2008/02/10 17:23
  • noremorse
10 Feb 2008 14:28
#193833
picc
  • noremorse
10 Feb 2008 14:33
#193835
picc 2
Post edited by: noremorse, at: 2008/02/10 17:35
  • noremorse
10 Feb 2008 14:37
#193836
any one think they could figure out the year of motor? maybe? please! tehe
  • loudhvx
  • loudhvx's Avatar
10 Feb 2008 22:48
#193911
You might be able to use this simplified diagram to get it running. If you have a mechanical advance unit, the ignition is an early KZ transistorized igniter, but not CDI. You can find a used igniter on ebay, or you can make one.
www.geocities.com/loudgpz/GPZgmHEImod.html
I drew this for an 81 550, but it should be pretty similar to yours. If you have 3 yellow (or white) wires from the alternator (with permanent magnet flywheel) you can use electronics (igniter and Regulator/rectifier) from many 1980, 1981, and 1982 KZ's.
Someone else would be better at identifying the exact year of the motor than me, but it looks like early 1980's to me, if not 1979. What's the number on the motor?
Post edited by: loudhvx, at: 2008/02/11 01:54
  • noremorse
11 Feb 2008 00:17
#193916
wow now that puts some light on my shady day! thanks for the layout,,(sincerly),,,the number on the motor is kzt00ae09220 maybe someone can tell from that ,,,thanks agian,,,,
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
11 Feb 2008 03:20
#193918
Hello noremorse...are you missing a digit in the motor VIN? There should be six numbers after the 'E' and your numbers tell me it is a 1977 model...which it shouldn't be 'cause the head is wrong. I suggest you look again.:)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Jack
  • Jack's Avatar
11 Feb 2008 11:16
#193984
noremorse wrote:
picc 2 <br><br>Post edited by: noremorse, at: 2008/02/10 17:35
That's a 79 or 80 KZ1000 MK ll motor. USA model with the pollution ports in the rocker and also has the factory painted blackout on the dyno cover.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
  • BSKZ650
  • BSKZ650's Avatar
11 Feb 2008 12:01
#194001
Is that a old Nance sprint car chasis?
77 ltd1000, current rider
76 kz900, just waiting
  • noremorse
13 Feb 2008 21:35
#194502
oops srry i forgot the last number its a (o) and the frame was a old circle track racer that i found,,ive done alot of work on it ,,its close,,,
