Bullet connector crimpers.
- kenskz1000
22 Oct 2007 16:42
Does anyone know where to purchase the special crimpers to crimp stock bullet connectors. I bought my connectors from Z1 Enterprises but dont see the crimmpers in Jeff's tool section.
- wiredgeorge
Re: Bullet connector crimpers.
24 Oct 2007 06:26
There is a good possibility that the crimpers you need are available thru Z1E but not shown on their site. In other words, call them and ask. There are many electrical components and tools not on the Z1E site that are in the parts catalogs available to them that they can order but probably don't stock as there isn't a lot of call for some of these products.
- Biquetoast
- King Jeremy The Wicked
24 Oct 2007 07:01
I don't have an answer, but I have $0.02 to add to this...
I, personally, take every opportunity like this to remove the bullets, and solder the connection, adding a jumper connection if necessary.
By the way, I *have* bought crappy little bullet connectors in the past (from AutoZone, not z1enterprises), and they didn't have a snug enough fit to connect to the existing bullets. So I ended up replacing both sides of the connection. Eventually, I just soldered it together anyway...
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- hardr0ck68
- Who put the what in the where?
24 Oct 2007 07:16
he does have them listed in the tool section, or did 4 days ago when i looked. I have bought the bullet connectors from Jeff and they fit perfectly.
For the bullet connectors a cheaper wire crimper will work well enough, but if you want to install the small pin connectors for block terminals you will want to get a nice crimper (as i have found out!).
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- otakar
24 Oct 2007 09:07
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- bill_wilcox100
24 Oct 2007 12:02
Ditto to what Biquetoast said! A good hot solder joint has never failed me yet. Many a fine looking crimp has. For the extra time and material required, I ALWAYS go for a soldered joint.
If one is not familiar with the difference between a hot solder joint and a cold solder joint then a really good crimper, one made specifically for that connector and wire gauge, may be the next best solution.
I have worked in production and used crimped connectors of many types and they are very good and are even MIL spec approved. But this was done my skilled personnel using purpose built dies and calibrated crimpers. Me, I can't afford that stuff but I can afford soldering materials.
By the way, unlike the connectors I bought at Canadian Tire, the Z1 supplied connectors were always compatible with the original and with the matting metric contacts.
Like Biquetoast, just my 2 cents. Best of success.
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Upgrades:
Montreal, Canada
- otakar
24 Oct 2007 13:45
The crimpers from "vintage connections" is a locking tipe crimper and will not reliese until the crimp is complete. Here is an example I did on my custom GPZ1200 project.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- bill_wilcox100
24 Oct 2007 14:16
Looks good, looks pro. Which tool did you use? How did the crimps fair in the pull test?
Upgrades:
Montreal, Canada
Upgrades:
Montreal, Canada
- hardr0ck68
24 Oct 2007 16:38
Wow, nice site! I am sold, I bought a terminal kit from Z1 and the sizes match nicely, but I really look the looks of that crimping tool.
I can't Wait to get my new toy!!
1977 kz650 c1
- otakar
24 Oct 2007 17:35
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- bill_wilcox100
24 Oct 2007 19:59
Did I mention very pro! Thanks.
Upgrades:
Montreal, Canada
Upgrades:
Montreal, Canada
- kenskz1000
