Headlight flashes when using other lights
- valvesprung
18 Aug 2007 19:42
Now that she's running like a champ, I'm having lighting issues.
Every time I use and of the lights (i.e. signals, brakes, high beam) I get a flickering in the headlamp. It actually dims and then flicker after the other light is turned off. It's worst with the turn siganls, but they all do it. I'm not sure what it's called, but the component pictured gets really hot (too hot to touch) after a few minutes. It's corresponding fuse also gets very hot, but doesn't pop (indicating resistance somewhere, not an overload).
Can this pictured component be the problem, any other suggestions on where to look? Thanks in advance
Jordan Green
HM Motorsports
HM Motorsports
- bill_wilcox100
Re: Headlight flashes when using other lights
18 Aug 2007 20:48
Could you indicate your bike's year, model and your location in your signature. This will allow members to more easily know if they can help you or not
Best of success.
Best of success.
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Upgrades:
Montreal, Canada
- bill_wilcox100
18 Aug 2007 20:49
Double post.
Post edited by: bill_wilcox100, at: 2007/08/18 23:49
Upgrades:
Montreal, Canada
Upgrades:
Montreal, Canada
- valvesprung
19 Aug 2007 00:52
Fixed...thanks!
Jordan Green
HM Motorsports
HM Motorsports
- bill_wilcox100
19 Aug 2007 05:20
Others might have or will have the same symptom. Could you share with us what the fault was and how you found it?
Have a great riding season!
Upgrades:
Montreal, Canada
Upgrades:
Montreal, Canada
- valvesprung
19 Aug 2007 09:36
Sorry, the bike's not fixed, my sig is
Bike still has the same problem...
Jordan Green
HM Motorsports
HM Motorsports
- valvesprung
19 Aug 2007 12:15
Quick thing to add...
The bike is getting harder and harder to kick over...the Neutral light seems dimmer each time I go out to start it, and it takes more kicks...
It seems like the bike may not be maintaining a good enough charge, what do you guys think?
I just really want to get a couple of good fairly worry free rides in before the rain returns...thanks Oregon...
Jordan Green
HM Motorsports
HM Motorsports
- valvesprung
20 Aug 2007 20:37
Help!!!
Jordan Green
HM Motorsports
HM Motorsports
- BSKZ650
21 Aug 2007 04:54
Have you checked the charging system, and the battery, bad grounds can play hell on a bike too
77 ltd1000, current rider
76 kz900, just waiting
- valvesprung
21 Aug 2007 10:42
I was getting 14 volts at the battery when running, but I haven't gone through all of the charging system checks yet, that's my next step...
Jordan Green
HM Motorsports
HM Motorsports
- pumps
21 Aug 2007 14:31
Have you got a manual? mine has a wiring diagram in the back. also here on the site in the database there is an electrical trouble shooting page you can down load. Really though the first thing that comes to my mind is check and clean all the connections you can find. get some stuff to spray on them. I use some stuff called De-Oxit I get at the supply house.Behind the head light there are quite a few important connections made. If you don't know how to use a multi-meter to test stuff it's a good idea to learn.And they are relatively cheap to buy.
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
1977 Yamaha XS650
2000 Kaw W650
- valvesprung
21 Aug 2007 21:30
I'm a certified auto tech, but as I've said elsewhere, bikes are new and a little daunting. I ran through the manual and found that my rectifier failed the test, and once I find one of those I'll test the rest of the system.
Any other suggestions?
Jordan Green
HM Motorsports
HM Motorsports
