Headlight flashes when using other lights
- loudhvx
Re: Headlight flashes when using other lights
21 Aug 2007 23:38
YOu should be able to get your rectifier and regulator from
www.oregonmotorcycleparts.com
in Oregon... how convenient.
If the fuse is getting hot, there couldbe a bad connection at the fuse. It is very common for the fuse contacts to be so dirty they heat up.
Post edited by: loudhvx, at: 2007/08/22 02:40
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- valvesprung
22 Aug 2007 07:29
The fuse contact look great as far as I can tell, but I'll pull out the fuses and give them a good cleaning.
The bike is outting out little to no charge when it get even close to idle which concerns me a bit...
Jordan Green
HM Motorsports
HM Motorsports
- bill_wilcox100
22 Aug 2007 10:12
If cleaning the fuses and the metal parts of the fuse holders does not eliminate the hot fuse symptom you may want to consider upgrading to a more modern "blade" type fuse... I eventually had to.
This is what mine ended up looking like. Notice that I added a separate 5 Amp fuse for the WG Coil Re-powering Mod.
Best of success!
Post edited by: bill_wilcox100, at: 2007/08/22 13:14
Post edited by: bill_wilcox100, at: 2007/08/22 13:18
Best of success!
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Upgrades:
Montreal, Canada
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
22 Aug 2007 10:42
Interestingly, I had the same problem start to happen as I was riding last night, and I remembered seeing this thread.
The headlight was running rather dim, and when I turned on the turn signals, or applied the brakes, the headlight would return to full brightness.
When I got the bike back home and started looking at the wiring, I found that the white wire that comes out of the (+) battery cable (and terminates in a double connector, with one wire going to the fusebox, and the other going to the rectifier, I think) had corroded clear through on the end where it attaches to the battery cable. I clipped off the end of the wire where it was corroded, crimped on a loop connector (not sure if that is the proper name for it), and connected the wire to the (+) post of the starter solenoid. Problem solved.
West Linn, OR
- valvesprung
22 Aug 2007 16:56
Well I'm really glad to hear that, as I know the wiring is good, it makes me more confident in my failed rectifier theory...thanks.
Jordan Green
HM Motorsports
HM Motorsports
