Broke down in Heavy rain
  • Fourtoes
  • Fourtoes's Avatar Topic Author
16 Aug 2007 04:14
#164209
Yesterday I was on a round trip of 400 miles to see my folks on my z650.
Was going great until the heavens opened and I thought I got a flat as the steering went funny. Looked down and there was 2-3 inches of water on the road. Spray everywhere and heavy traffic.
At the same time the bike starts to splutter, lose power and cuts out.
Brown trouser moment at speed.
I pull over and cant get it started again. It makes a hell of a clanking sound and just dies. I push it to the service station and give it a rest. Its still torrential.
Give it another go, it starts eventually but still a little clacky, revs great and then doesnt idle makes a few groans and dies.
I check the plugs, air filter, battery, plug caps etc, and all seems fine.
Call the breakdown service and they are as much use as a chocolate fireguard.
Get towed all the way home, takes forever as the truck is restricted to 56mph max.
So my question is.....whats going on?
Do you think it could be the coils? It did sound as if it was misfiring. How do I check?
Cheers in advance from across the pond
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Broke down in Heavy rain
16 Aug 2007 04:40
#164213
check wiring under tank.B)
  • Fourtoes
16 Aug 2007 04:58
#164215
Had the tank off at the time to check wiring, all connections good and I sprayed with WD40 (water dispersant). Do you get that in the US?
  • donthekawguy
  • donthekawguy's Avatar
16 Aug 2007 05:15
#164216
Try pulling off your ignition cover and make sure it's dry in there. You might also have water in the tank. Put a little gas dryer in it and see if that helps.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • Fourtoes
16 Aug 2007 05:44
#164220
Yep checked the ignition cover at the same time, was a little wet in there. Is there supposed to be a gasket there as there wasn't one?
  • Bluemeanie
  • Bluemeanie's Avatar
16 Aug 2007 05:58
#164225
I did not have a gasket for years but then I don't ride in the rain. While installing the Dyna S I made a gasket so I'm good now. Yes, gasket required for rain riding!! ;) Did bike run OK after drying points??
Post edited by: Bluemeanie, at: 2007/08/16 09:00
  • Fourtoes
16 Aug 2007 06:30
#164229
Its still raining in the UK. British summers eh!
  • patmann
  • patmann's Avatar
16 Aug 2007 08:10
#164240
Just a thought... DO you have pod air cleaners? Or the stock box?? If you have pods ( individual cleaners non stock ) they might have soaked up enough water and gotten it into the engine?? maybe?? Just a shot in the dark:dry: But I would think that after a few minutes that would have cleared up, unless they are soaked and still allowing water to get into the carbs some how..??
Pat
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
  • steell
  • steell's Avatar
16 Aug 2007 08:34
#164245
I had a 750 twin that ran absolutely great, until the first raindrops hit it, replaced the coil and wires and that fixed the problem.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
16 Aug 2007 11:45
#164270
I had the same problem in rain. My coils were getting wet with water being sprayed up under the tank. I had a shorter LTD fender up front.
I sprayed an electrical sealer all over the coils and wiring under the tank, and have had no trouble since, in over 2 years.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • BSKZ650
  • BSKZ650's Avatar
16 Aug 2007 14:02
#164293
sounds like water in the carb syndrom to me, Igot caught in a down pour a few weeks ago, took it about 15 min of low gear high rpm, missing no power riding for it to clear out
bottom line,
BIKE + RAIN = TROUBLE:sick:
77 ltd1000, current rider
76 kz900, just waiting
  • bill_wilcox100
  • bill_wilcox100's Avatar
16 Aug 2007 18:55
#164338
Yes, there should be a gasket under the points cover. When I was in a jam I used a cerial box card board and cut out a rough gasket and oiled it to make it water proof... worked well until I could get the real thing.
On my bike there is also be a gromet on the point cable coming under the points cover. Again, if you're jamed-up you can use a tube of silicone sealer.
Best of success.
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
