ignition? or carbs?
  • freebyrd24
  • freebyrd24's Avatar Topic Author
ignition? or carbs?
24 Apr 2007 17:11
#133598
im not exactly sure what is causing my little problem.
i just got the 650 out a few weeks ago of its new england winter sleep and its actin up on me. at start up the last 3 times ive ran it, i am runnin on 3 cylinders. it runs terrible, and once i pull out of my driveway the last clinder will sputter on and everything will be okay.
i checked the plugs and cleaned them and everything seems to be okay. the bike pulls hard all the way to redline right now. am i dealing with a slightly clogged jet? or could this be my stock points ignition system? any suggestions? ive thought about the coil mod, but really neeed to read how its done, ive just read about results. thanks
- 1981 KZ1000-K1 LTD - Long term project
1075cc Kit - New Wiseco Pistons
Sold:
- 1978 kz650 SR, 4-1 Vance and Hines Full Exhaust, Dyna-S Ignition, Accel Coils and Wires
  • BSKZ650
  • BSKZ650's Avatar
Re: ignition? or carbs?
25 Apr 2007 04:53
#133730
sounds like a carb thing to me
77 ltd1000, current rider
76 kz900, just waiting
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
25 Apr 2007 06:37
#133768
Could be a bad connection somewhere from the coil to the spark plug. Either the spark plug cap or wire.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • arobsum
  • arobsum's Avatar
25 Apr 2007 17:37
#133967
yep...that one carb may be lean or something similar..
  • TwoSeven
  • TwoSeven's Avatar
25 Apr 2007 17:57
#133974
At a guess it sounds like a cold fouled plug. Probably an idea to replace it.
  • freebyrd24
25 Apr 2007 19:06
#134003
i checked and cleaned the plugs, im going to replace those within the week. but these new england winters r nothing friendly. im goin to run some sea foam through the tank first, since the LAST thing i want to do is take carbs in and out of place with the stock air box and holders
Sold:
  • BSKZ650
  • BSKZ650's Avatar
27 Apr 2007 04:49
#134513
I fought the stock air box once, after a long battle I got it back on.
I then made a run to the bike shop and bought a set of pods
  • outatimeoutlaw
  • outatimeoutlaw's Avatar
29 Apr 2007 06:17
#135195
A friend of mine who worked in a bike shop for years says NEVER run any chemical claeners through a diaphram carb!! I think ya should check the rubbers between the carbs & the head for vac leaks. Also as I said on here before, you can pin it right down with an automotive lab scope.
  • freebyrd24
29 Apr 2007 07:31
#135208
rubbers are all brand new. no vac leaks
Sold:
  • freebyrd24
15 May 2007 17:14
#140415
so a recent update....
the bike is cutting out ever so slightly at 7,000+ RPMs. and it is still experiencing the less than 4 cyl initial start-up here and there. i checked the plugs after a ride today and one plug was pretty carbon fouled after cleanin them just the other day. 3 of them looked good though. i believe the carbs r ok due to the great throttle response i get and am really suspect of the plugs. im going to go buy some and test by the end of the week. any other ideas? Thanks for all the responses!
Sold:
  • kzwolfsr
  • kzwolfsr's Avatar
15 May 2007 17:16
#140418
Drain the carbs.
Original man of the Caribbean
  • vach
  • vach's Avatar
15 May 2007 17:46
#140425
I would change the plugs.. I have a 66 Impala that doesn't get driven and when it sit's for months at a time I almost have to always change the plugs.. Something about sitting for awhile.. When I start it after months, 1-2 plugs won't fire.. The motor is a racing motor and only has 12,000 miles on it.
Post edited by: vach, at: 2007/05/15 20:55
1979 kz650 B. Chicago, Illinois
