Biquetoast and whoever else....
- Biquetoast
- King Jeremy The Wicked
Re: Biquetoast and whoever else....
03 Apr 2007 14:02
shawntmartin wrote:
And, in truth, your work has only begun. Remember, this all was to get you a good *baseline* for setting the other things: rebalance the carbs, set pilots, timing, etc....
Well, *one* of the plugs says different. Besides, air leaks can manifest themselves unpredictably.......That would indicate it was lean but the plug says different. Anyway, as long as it doesn't happen again, Im good!!
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- shawntmartin
04 Apr 2007 09:29
Would you say that starting the bike and having it idle 15-20 minutes (no revving) and shutting it off to check the plugs is a good enough way to tell if the pilots need adjusting? Maybe do this process a few times? I figure they only do the idle circuit right?
- Biquetoast
04 Apr 2007 17:14
shawntmartin wrote:
I don't think its good to leave it running sitting still like that. It sure would get hot... Why not put-put around the neighborhood at low rpm?Would you say that starting the bike and having it idle 15-20 minutes (no revving) and shutting it off to check the plugs is a good enough way to tell if the pilots need adjusting? Maybe do this process a few times? I figure they only do the idle circuit right?
kz750twins.com
kz750twins.com
- outatimeoutlaw
07 Apr 2007 06:41
If you have an auto tech friend with a snap on modis or similar lab scope you will learn a lot about what is actualy happening in the cyls. (just a thought )
Post edited by: outatimeoutlaw, at: 2007/04/07 09:42
- racer54
07 Apr 2007 11:46
Can someone tell me where to find the original instructions for doing the coil relay modification? I've searched but all I come up with is someone in the middle of doing the modification. Must be a topic in here where it was told how to do it from the beginning. Interested in doing it myself but can't find the original text. Where did you guys hide it?
- Biquetoast
07 Apr 2007 11:52
racer54 wrote:
Please see this thread for an explanation...
...and by the way, it is commonly referred to as the "coil mod" around here, so if you search for that you'll find tons...
Post edited by: Biquetoast, at: 2007/04/07 14:52
kz750twins.com
kz750twins.com
