BATTERIES
  • outatimeoutlaw
  • outatimeoutlaw's Avatar Topic Author
BATTERIES
03 Feb 2007 14:30
#109964
WANT YOUSE GUYS OPINION. What is the brand of the best battery you ever had in a bike ?
THANKS TO ALL WHO RESPONDED. I'm gonna go with sla batt.
Post edited by: outatimeoutlaw, at: 2007/02/11 08:54
  • RonKZ650
  • RonKZ650's Avatar
Re: BATTERIES
03 Feb 2007 15:24
#109972
I always try to stay with Yuasa. They used to always be USA made, now many are made in Taiwan unfortunately.
Re: BATTERIES
03 Feb 2007 16:11
#109988
Sealed, maintenance free, battery. No filler caps, no vent tube, no hassles. Will never have anything else. Costs $20 more and worth it the first time you don't have to goof around removing the battery to check and service cell levels.
  • racer54
  • racer54's Avatar
Re: BATTERIES
03 Feb 2007 16:38
#109997
I've always had good luck with Sears Die-hard batteries, but like the idea of no-maintenace batteries. Might have to give those a try.
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
Re: BATTERIES
03 Feb 2007 18:33
#110008
I really believe that nearly all batteries will last a long time if they are taken care of. I bought a "Dorcy" battery from an auto parts store for $25 and it lasted 8 full seasons! I do plan on going with a maintenance free the next time. I like the idea of no vent hose and no levels to mess with.
The Kaw List:
  • JimatMilkyWay
  • JimatMilkyWay's Avatar
Re: BATTERIES
03 Feb 2007 19:34
#110022
I too have had good luck with Die Hards, but as 79MK11 stated above, he got a $25 batt to hold out 8 yrs.
Proving once again, that it is a bit of a crap shoot if you axe me.
  • tnutz
  • tnutz's Avatar
Re: BATTERIES
03 Feb 2007 20:44
#110034
must be why mine died in 2 months with a perfectly healthy charging system...and 40 bucks to ship it back for warranty. i guess i will just spend the extra and buy a new.
  • JimatMilkyWay
Re: BATTERIES
05 Feb 2007 16:51
#110439
I'm not too sure 'bout batteries from Yuasa, guys.
  • hydrolazer
  • hydrolazer's Avatar
Re: BATTERIES
05 Feb 2007 17:21
#110443
i love my maintenance free battery,,no danger of acid over flow on the pipes either
\'79 kaw 1000 ltd
  • Shoe48
  • Shoe48's Avatar
  • Live each day as it is your last
Re: BATTERIES
05 Feb 2007 18:31
#110456
Batterymart.com ,, I have a SLA battery aand its been in two bikes now ,, I have been checking the voltage drop since it has been sitting ,, Still the same after a few months ,, :)
  • JimatMilkyWay
Re: BATTERIES
05 Feb 2007 21:12
#110479
Your unloaded voltage is not the test/check you need to do, as you will get 13VDC across a battery that is so "dead" it would not even light a flashlight bulb. Your battery's ability to provide ample current is the true test to perform. "Well how do I do that?" you ask. Well I'm real glad you asked that question. The following procedure applies to any bike, any battery, every time. The simplest test, if you want to get a useful indication of your battery's capacity, is to first pull the wires off the spark plugs. Then have a friend hold the starter button so the starter is cranking the engine over, with the lights on and any other electrical "drain" you can come up with. While this is going on, hold your voltmeter across the battery posts. Your cranking voltage should drop no lower than 10.5 volts or so. Certainly no lower than 10VDC.
Further, if you literally hold your test leads on the posts, as opposed to the cable clamps, then you have also eliminated the battery connections as a possible problem. If you think your battery is dead/discharged, then first charge your battery, then do the test before buying a new battery. If your battery will charge, then you do the test the way I have described, and the battery voltage does _NOT_ drop appreciably with your meter connected at the posts, _not_ the clamps, then you have a loose connection on at least one clamp. Either that, or something else is not allowing the starting voltage and current to make it's way to the starter circuit.
Flame throwers to the up and ready position!?
Further still, if you do have your lights on, you engage the starter, and the battery is weak, then the lights will always go out, because the voltage drop across the battery will not supply power to lights if it won't supply power to the starter. This little observation can tell you when the battery/charge circuit needs some attention before the battery is completely gone. Not always, as the battery can just fail totally and suddenly, but it will usually give a sign first. If your starter button is pushed and the lights do NOT dim or go out, then it is not the battery that is at fault, and you need to look at the starting circuit.
  • JimatMilkyWay
Re: BATTERIES
06 Feb 2007 17:13
#110658
outatimeoutlaw wrote:
WANT YOUSE GUYS OPINION. What is the brand of the best battery you ever had in a bike ? ....
"Not sure 'bout batteries from __Yuasa, guys__ ya get it??? kzrider.com/components/com_joomlaboard/emoticons/w00t.png
Whoops;
That didn't seem to work.
Post edited by: JimatMilkyWay, at: 2007/02/06 20:14
