Dual headlights
- DasTeufel
Dual headlights
28 Nov 2005 17:27
I ride my KZ daily to work. Part of my commute is riding in the wee morning hours. I have an automotive H6024 installed currently, it is brighter than stock, but I would still like more light. I would like to go to a dual headlamp setup, but some of my concerns are: what can I use and still be DOT legal, and will my existing electrical system operate it (if I have to do some modifications it's no big deal). Your thoughts?
2009 KTM 690 SMC
2008 Kawasaki Ninja 250R
2001 Suzuki GSXR 750
Wildomar, CA
Wildomar, CA
- Biquetoast
- King Jeremy The Wicked
Re: Dual headlights
28 Nov 2005 17:37
I'll tell you what I did (and what I'm doing) in a nutshell, and I hope it helps...
I changed my turnsignals and taillight to LED to reduce the load.
I did WG's "Coil Mod" to help the spark to be reliable.
I clipped every bullet-style connection I could find and jumpered and soldered because the old wiring is pathetic.
I dream of having one of those dual headlights, but they cost way too freaking much. In the mean-time, I wired in a foglamp/running light at about 45 watts that I run with my low beam when needed. When I try to run it with my high beam, the bike lets me know it isn't happy...
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- DasTeufel
Re: Dual headlights
28 Nov 2005 17:43
My intentions are to fabricate them. loudhvx has something similar on his bike, looks like two driving lights.
2009 KTM 690 SMC
Wildomar, CA
Wildomar, CA
- donthekawguy
Re: Dual headlights
28 Nov 2005 20:29
I got a set of the duals from americanclassix.com and love them. They are spendy, but I owed myself a x-mas present that year.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- Biquetoast
Re: Dual headlights
28 Nov 2005 21:01
donthekawguy wrote:
Yep. Those are the ones I meant by "cost way too freaking much"...I got a set of the duals from americanclassix.com and love them. They are spendy, but I owed myself a x-mas present that year.
kz750twins.com
kz750twins.com
- OKC_Kent
Re: Dual headlights
28 Nov 2005 21:19
Is the H6024 a halogen light?
I did a headlight conversion to a H4 halogen 55watt low / 60watt high beam from JC Whitney. It seems pretty bright and cost about $20.
Cashion, OK
78 KZ650 B2 85,000+ miles
- DasTeufel
Re: Dual headlights
28 Nov 2005 21:47
I believe it is, I would need to recheck that. Not only am I trying for more light, would like to "update" the look of my bike a bit.
2009 KTM 690 SMC
Wildomar, CA
Wildomar, CA
- loudhvx
Re: Dual headlights
28 Nov 2005 22:52
Mine were $15 at Harbor Freight. I'm sure they are not DOT approved for headlights. They are 55W each so that's 110 Watts with no problem on the charging system. It actually takes stress off of the regulator to have more lights. You may have to upgrade the wiring a little bit though. You may also have to increase the fuse if you go much higher on the wattage. The key to being seen is not just wattage, though. You also need a certain amount of area on the bulb lit up. Projector beams are not very visible if the person looking at you is not in the beam.
Also, the shape of the beam will affect how much it lights up the road.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- wiredgeorge
Re: Dual headlights
29 Nov 2005 05:51
DT... You are worried about DOT regulations? Why? The DOT doesn't have police to check to see if you are using a DOT headlamp or DOT helmet... check your state's regulations! Every state has their own. In Texas, you could probably use 50,000KW headlight if you wanted to and no one would care. The regulations in some states for motorcycles are VERY VERY primitive.
As far as how that system would work? The shape of the reflector makes more difference than the power of the bulb. A round and traditional shaped reflector works best. If you go with dual lamps and are looking for the most light, I doubt the two smaller reflectors would do as well as a single larger reflector... If you are truly interested in seeing well at night, put your headlight on a dedicated relay (see coil powering mod) and go with HEAVY wiring out of your relay. Keep an eye on the rating for the bulb holder as well. Make sure it can stand more voltage going through it. The best bet will be a GOOD quality H4 bulb... perhaps a 100/55 would work or if you are really sporty, a 130/55.
Several years ago, I found that JCW sells higher power bulbs and I bought several 90/55 for a Vulcan. It turns out that these lower quality bulbs (and cheaper) cast a yellowish light and actually illuminated the road less than an aftermarket 65/55 superwhite bulb. Get a GOOD quality bulb from a company that is known for making light bulbs... a Chinese special may not work as well in this case!
- Ron G
Re: Dual headlights
29 Nov 2005 06:33
wiredgeorge wrote:
Periodic vehicle safety inspections and inspection stickers are mandatory in some states. A 50,000KW headlight would probably vaporize the inspector. :whistle:
Ron
Ron
- DasTeufel
Re: Dual headlights
29 Nov 2005 07:59
California doesn't have annual inspections for vehicles, but sometimes the PD get a little anal about motorcycles. Recently they started cracking down on bikes with loud pipes, aftermarket turn signals that were not DOT approved. Hence my reasoning for DOT approved lighting systems. The 6024 bulb I am using is halogen, but I don't know what the wattage rating is.
2009 KTM 690 SMC
Wildomar, CA
Wildomar, CA
- Fossil
Re: Dual headlights
29 Nov 2005 17:26
How about a pair of Bates 5 3/4" "chopper" headlights. They use a DOT sealed beam and have high beam indicators.
